| diyAudio Sponsor | ||
I swear,
I am a sucker for punishment sometimes, After setting aside the deathtrap Kay guitar amp I had posted about earlier this week. I decided to try and get something a little more or less safer working. OK, Here It Is, Dumont Model RA506 Mono upright console record player. So, I take the time to remove the 2 prong cord and wire in a nicer 3 prong jack and cord setup. Added a line fuse I converted the aux line socket into a place to plug in a remotely mounted encased power switch. I am pretty sure I wired the mains correctly, There is a clear view of it in my photo. I used the information I found Here Mains Since this baby is I'm guessing late 40's to early 50's, I kind of knew what to expect. ( A Nightmare) Tubes Tested perfect, I have 3 sets for this unit. 12AX7 1st & 2nd stage, 6C4 inverter, EZ81 rectifier, And 2 EL84's. So Anyway I get everything attached, And Proceed to power up. 15 seconds and I start to hear a mild hum from the speaker, Turn on the old mono turntable, Neat Music. But not very loud . About 20 seconds later I start seeing the first hint of Yep, You guessed it "SMOKE" SeeChassis Underside Photo I marked the referance items in red. Item "A" Componet that was smoking 56 ohm 5W Resistor My First guess, Of Course, Bad Electrolytic Caps. So I replace the Electrolytic Caps & Resistor. (the cap got pretty warm during power on) Ok, So now The Cap is new, And the resistor is new ( A & B in photo) I proceed to power up again, And now the music is much much louder, But still has conciderable background hum. About 60 seconds lapse and the 22K 1/2w Resistor (C in photo) Begins to emit a fine trail of smoke. I quick shut it down. And Thats where I am. Now this time the Electrolytic Cap wasnt even warm to the touch. I could sure use some ideas here, As this actually seems like a fairly decent amp for its age. Gene |
#2 |
The ceramic caps and the pot cases say to me mid-late 1950s maybe through the early 1960s. By the mid-60s it would "have to be" Stereo. I very much doubt that type of pot case was produced in the 1940s. Also the 10% resistors were uncommon in consumer gear through the 1940s. (20% was common through the 1950s.) And 6BQ5(EL84) was not widely used in the US until the 1950s. I can't say I've ever seen an EZ81 in US gear; does it have a 6xx4 number?
Yes, this is a better than average record player. Three tone controls, push-pull.... this was a DeLuxe model. If you kept the original speaker and cabinet, it should make fine sound. DuMont was a name to be reckoned with: Allen B. DuMont put his name on the first commercial oscilloscopes, worked in TV, leveraged that into a major TV network.... and then it all fell apart by 1960. The company continued for a while, and the name a lot longer, but your recordplayer seems to be from the end of DuMont's golden years. > seems like a fairly decent amp for its age. An age when mundane amps were built better than anything you see today, sonny. Oh, sure, you have to patch some smoke-leaks, but most of us that age have some leaks and bald-spots. > I converted the aux line socket into a place to plug in a remotely mounted encased power switch. Clever, but I dislike it on grounds that this remote switch now fits every outlet in the house, and can dead-short them. Be careful, or be clever a different way. As a guitar amp, it should be very nice, though power chords will soon destroy the shellac/paper speaker. A similar guitar speaker in the same cabinet might be very fine. You may need more gain than it has now, and the volume control at the input is not ideal for a high-gain guitar amp. What you need is one stage of 12AX7 before the volume control. Dunno where you put it; maybe punch out the phono input jack and mount a 7-pin socket, use 6AV6? Any resistor that has smoked HAS to be replaced. Or cut-out so you can smoke-check and volt-check the rest of the amp, and then come back to the parts fed by the smoked resistor. The 0.15 cap behind the treble control is blistered and surely not healthy. It is a lovely photograph but I'm not going to trace-out the circuit for you tonight. Dunno what your smoking 22K does, or what makes it smoke. What is that odd 5-socket connector with two large 4K7 resistors near the center? Can you estimate the proper tube voltages (plate, grid, cathode) and are the tubes working at reasonable voltages? Hard to know if it smokes faster than you can put a meter on. Look: in an amp like this, power current will probably go to zero with all the signal tubes removed. Take out 12AX7, 6C4, and EL34s. Power-up. Watch the main cap voltage. It may go too high, no-load, for the good of that cap, but it should hold for a minute and nothing should smoke. Then put the tubes back one at a time. I really doubt the 12AX7 stages can make smoke, I'd try the 6C4 and the EL34s, one at a time. If they don't smoke, check the voltages and see if they look reasonable. Especially check grid voltages: a leaky coupling cap will pull a "zero bias" grid way positive, which makes the tube suck big current. Don't run just one EL84 for more than a minute. With high B+ and a 2-tube cathode bias resistor under just one tube, the tube will overheat. But that should be enough time for a quick voltage check. |
#3 |
It looks like the 22k resistor goes to the EL84 screens.
If the resistor is smoking, one or both screens are drawing too much current. Possibly an internal short or a gassy tube. Change out the EL84 tubes.
Frank |
#4 | ||||||
Frank: Quote:
The Tubes are confirmed good on both my tester and my other amp. Heres rough start on the power supply schematic, Im going to try to continue drawing it out as I go. Schematic Oh, BTW, Heres a picture of the three pieces. The cabinets are in lovely condition. The 2 floor speakers are both 2way (12inch with 3 1/2 tweets) I am not sure if they are also from dumont, But they sure look like a match in style and finish. Dumont Unit Gene |
#5 |
Gene,
The other guys are way ahead of me. However, my math using P = I^2R says slightly under 5 mA. is a 0.5 W. through 22 KOhms. Could a higher wattage rated resistor be required?
Eli D. |
#6 |
Schematic may be available from Sams. It's in the index, but says "#488 - Servicer" so it doesn't have a complete folder like most. I'll look when I get home - I have some sets of Sams in that range.
#488 is 1960, but it's likely earlier. |
#7 |
Replace all signal caps and power supply caps. With the amp turned off and the caps discharged, measure the impendances of all transformers to check for shorts.
Also measure all resistor values; replace any 10%+ ou t of spec. |
#8 |
Also measure all resistor values; replace any 10%+ out of spec Interestingly, The PS Cap discharges almost as fast as I shut the unit off. I had noticed this prior to changing it. Something upstream must be the cause, But I can Find no dead solid shorts yet. The Transformers seem to be fine. I am suspect of a couple disc caps at this point, There really isnt much to test. I havent powered up again yet with or without tubes as Its not going to be fun nor quick switching out the remaining caps. I suppose its possible that the 22K 1/2 w resistor is under rated, I have never seen an amp with wattage that low in that area of the PS. I have built several nice project amps,(from schematics) but I am not designer. I am by no means a newbie with a soldering iron or working around HV devices. Its just been many years since I had first played with tubes. It cant be to bad off as it did emit sound for 30-45 seconds, And the smoke wasnt more than just a fine hint of a trail(almost not visible) Had the unit been in the cabinet it might have been overlooked until it was dust. Gene |
#9 |
No (I think). Rectifier feeds through 56 ohms to lower-left main cap lug. That feeds both screens and the OPT CT. It also feeds the 22K to the top-right main cap lug, which runs left over an orangish wire to three resistors in the preamp/driver area: 100K to 6C4, 470K to right side of 12AX7, 100K? to left side of 12AX7. Perfectly reasonable values. Pull the little tubes. In that condition there should be no voltage drop on the 22K. If there is, then cut the orangish wire. If the 22K still shows drop, the top-right unit of the main filter cap is leaking all to heck. > where an electrostatic tweeter plugs in. Ah. Obvious once 40 year old memory cells are rung/wrung. There was a line of really low-cost electrostats. They didn't work very well. Supply or reliability may have been problematic, leading to using dynamic tweeters to get boxes out the door. > picture of the three pieces. The cabinets are in lovely condition. Ah, surely late-1950s until mid-1960s. Also the bookends and even your wall paneling is of that era. I'm inclined to think the speakers were not made FOR that main console: difference in the corner trim and base molding. I suspect the speakers are newer (or newer-design) than the main box. But they may have been options suitable for several main-box models. Even a trick to move some older-production mono boxes onto a "Stereo" market, by adding two external speakers (on one amp: who will know?). If you say they have the same finish, likely they are from the same woodshop and same general contract. IAC, a real find. Two paper 12-inchers may survive the output of this amp even in guitar duty. If they are 1-inch voice-coil, they sure should eat 5W-8W power chords all day long. For heavy-metal, you might want to discretely switch-off the tweeters so they don't smoke. |
#10 | |
rgrds, Brad |
| Zen V4 smoke.... | rebojorge | Pass Labs | 8 | 20th December 2007 08:34 PM |
| T-amp up in smoke | jwb009 | Class D | 21 | 4th April 2006 06:50 AM |
| Oscope Dumont 190 | infinia | Parts | 3 | 9th March 2006 09:45 PM |
| I let the smoke out. | TerryG | Class D | 16 | 8th November 2005 06:25 PM |
| bringing up aleph 3, no smoke, but no sound | cowanrg | Pass Labs | 24 | 20th May 2004 11:29 PM |
| Page generated in 0.22237 seconds (69.41% PHP - 30.59% MySQL) with 11 queries |
