diyAudio Sponsor
Old 19th July 2005, 02:19 PM   #1
kmtang is offline kmtang  Canada
kmtang's Avatar
Default Purist 2 Line Amp
I built this Purist 2 Line Amp but omitting the first stage. I thought I don't need too high the gain.
The details are in http://www.normankoren.com/Audio/Spi..._2.html#Purist
The difference between this with similar circuitry is that the first stage employs local feedback to reduce the distortion.
Johnny
Old 19th July 2005, 02:21 PM   #2
kmtang's Avatar
By the way, I used 6SN7 instead of 12AU7.
Old 19th July 2005, 07:26 PM   #3
wa4swj is offline wa4swj  United States
Hi Jonny,
My first post to this forum - How does your line amp sound? I've been very impressed with Norm's analysis of tube circuits and was wondering how you like the circuit. One fine day I'd like to build a copy of his "TENA" power amplifier - if I can ever get time!
Ed Long
Ed Long
Old 19th July 2005, 07:43 PM   #4
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
Welcome to the forum, Ed, I hope you enjoy it - you'll find the "Tubes" section quite busy.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 20th July 2005, 04:19 AM   #5
Default what AUthority do you have for the saturation on the Leak St 2O
was it in a published test, I doubt it was Haden Boardman.
First up the tests of the original way back by Hifi-News&RR, reported some 11 watts @ 20 Hz, and similar for the same OPT's on the 12 Plus.
And as stated in my post in response I measured 20 Hz @ 20 watts in pentode mode with just 1.5%D, with lower total feedback and a CCS on the different splitter tubes, I used 6CG7's. for this.
Further I have run the pentode chassis item into EBS 300 liter 15inch DC gold Tannoys, measured 20 hz sine waves at 98 decibels and b-all doubling. Okay?
As I said the bass limitaions in the Leaks in OEM form may have more to do with the PSU, I can't remember the model no. on my OPT's but there were several different iterations in the St20's life. I was told by the unofficial Leak site owner and writer of the recent book, that the ones I have are quite up to the job.
Timbo,
puzzled
Timbo
Old 20th July 2005, 05:13 AM   #6
kmtang's Avatar
I still haven't check the waveform and frequency response of the line amp.
I have listened to it for couple days. It sounds pretty good to me. It's rather airy, open sound, fast.
Johnny
Purist Audio Design Museaus 6M XLR for sale serraniruben Swap Meet 1 7th January 2012 05:06 PM
Akai GX 265D line voltage on line outs? ShorBird Solid State 11 26th January 2009 11:44 PM
Peerless V-line XT line woofer discontinued first_1st Multi-Way 1 12th August 2008 04:55 PM
Line array tweeter line - On left or right? dhenryp Multi-Way 4 9th March 2005 11:35 PM
how to combine Line array and transmission line together Jared Multi-Way 5 19th April 2004 10:32 PM
Page generated in 0.10521 seconds (64.15% PHP - 35.85% MySQL) with 11 queries
