diyAudio Sponsor
Old 19th July 2005, 08:49 AM   #1
CLS is offline CLS  Taiwan
Talking Yet Another "EURIDICE" Pre Amp, 4CH This Time
Hi there,
Quite many related posts here somewhere, but they are all very long already, so I'd like to create a new thread.
Back in '97 when I read about the Euridice pre amp on the <Sound Practices>, I thought "this is it!".
All these years I've been thinking of it. And my own thoughts about "pre amp" have also been evolving continuously. (especially the concept of digital xover made a big impact)
My own "designs" around original Euridice had evolved to several versions including differential pair, with regulated supply, or even shunt regulator with pentode current source & the likes. I've drawn 5~6 versions of the schematics of such line stage & power supplies. And they looked more & more complicated. In the end, it seemed that I just wanted to use as many tubes as I have on hand, instead of seeking the best & proper solution.
My previous pre amp was SOZ, sounded OK. A little bit vague in the high & soft on bass but overall open & warm-balanced. And I had an OPAmp-based 2nd order LP filter for the bass amps.
Now I want to combine the pre amp & the active xover into one chassis to simplify my system. So, actually I need 4 active channels in this unit. With this construction, no matter I use it analogically xover now or digitally xover in the future, it's ready as a convenient platform.
After thoroughly readings & thinking, I dropped those complications & made it as simple as can be. Back to basic & decent executions are all I need.
So here it is:
1) LL7902 wired as 2:1 step down input transformer with a 10k load (stepped volume control). I'd like to make a relatively easy load to the upstream equipment. I've tried "DAC chip-direct" with this transformer and got a very good sound. I'll probably do it again. Now the transformers are much further from the chip, so a step down would make it an easier load.
2) The wiping arms of the stepped VR are connected to 2 loads: 1 for passive 1st order HPF & the other to a 2nd order active LPF, both gain stages are mostly original "Euridice".
3) Output transformers are LL1660 (18mA), wired as 4.5:1 (or, 5k:250R approx. )
4) Powered by 2* 6X5GT with 2* 1N4007 as one & a half bridge, fed into 2* 15H/220uF LC, then splitted into 4* 2k/1000uF RC for each tube.
Layout:
Notice the left, see the "relay socket" ? It's because the limited height, I can not afford to elevate the normal 8pin socket in this cabinet. And I found it a breeze to connect around such socket. Easy & neat!
The output transformers are arranged so for avoiding/reducing magnetic coupling to each other & the power chokes. But I confess, I've done this by "pure guess", instead of real experiments. (There are A LOT OF holes to drill on the chassis, I don't have time to build-test-rebuild... ) I've thought about separating the power portion to another cabinet, but that complicated things in some ways.
There's a massive terrible hum in the first test. Tens of mV of hum! Then I made a virtual CT of the heater winding by 2* 47R & connected the center to ground. That cured the hum mostly but not entirely. ( I'm confused, aren't those heaters insulated from cathodes? Why can't I just let them float? )
In the first 2~3 hours, it sounded awful, really. Strained in the high & bass was non-existent. After that, it loosened up nicely with good extension on both ends. It's sounding good indeed, with crisp trancient, clean & lively performance, but the "upgrading effect" was not so astonishing as Oris horn in my system. Listening carefully, it's surely an upgrade to my previous SOZ in every respects, but not so hugely as expectation. (my SOZ was biased at 40mA, I like the sound of "big current" )
Concerns & possible tunings:
1) Hum! It's still there, although barely audible on the listening position, it'd of course be better totally gone. I got approx. 0.5V ripple on the B+, but there's no space for more LC or RC. And the heaters are AC powered.
a) Does Ultra-path work on such circuit? If the hum is partially caused by magnetic coupling, does Ultra-path help?
b) Is DC heater necessary or any help?
2) I got 155V B+ after LCRC, 5V shied of the original 160V. With the same 120R cathode resistor, I got only -1.7V bias, which is only 14mA. In the Raytheon specs, it recommand 150V B+ with 60R cathode resistor to get -1.5V bias & 25mA, so I'll probably try this. This tube seems prefer high current to high voltage. So I'll try maintaining the B+ with more current.
3) LL1660 output transformer has 100H in the primary winding. With pretty low plate resistance of CK5842, ideally I can get very very low frenquency out of it. To let them sing all the way down, I use huge cathode bypass caps here - 1000uF in mid-high channels & 2200uF in lows. I'm not sure, before realizing the lowest 1.3Hz or 0.6Hz, there might be other evils coming up. Or, once I try smaller cathode resistor, this "issue" would be mostly gone?
4) 2:1 step down on the input seemed unecessary. And it made the total gain too small, I'll probably rewire them into simply 1:1 isolation. Working around those tiny pins is really painful though...
5) I got several 6C45 lying around, maybe worth a try in this circuit. I've had a simple test on microphonia by tappin on the glass. The CK5842 has a relatively firm & short "tung", and the 6C45 in my 300B power amp has a crisp & very long "ding-ring-ring-ring- ing -ing -ing -ing -ing ....... ". ( Except for tubes themselves, maybe it's also because the 6C45 is working under plate choke / direct coupling with most of its natural amplification, and the 5842 is working with a largely stepped down output trans. I'll do more experiments on these tubes.... )
So, thanks for reading such a long post. It's probably an "old" topic.
Any corrections, suggestions, & thoughts are more than welcome.
Old 19th July 2005, 11:18 AM   #2
Gluca is offline Gluca  Italy
tarmac ripper
Gluca's Avatar
So clean! My amps are quiete a mess. You are making mr Lundahl rich!
Where did you find those nice relay sockets?
Are you sure your input trans/wirings are not picking up hum somewhere?
Ciao.
Old 19th July 2005, 12:52 PM   #3
jlsem is offline jlsem  United States
jlsem's Avatar
The two chokes may be coupling ripple to each other.
John
Old 19th July 2005, 01:13 PM   #4
Previously: Kuei Yang Wang
ThorstenL's Avatar
Default Re: Yet Another "EURIDICE" Pre Amp, 4CH This Time
Konnichiwa,
Heater and cathode form a parasitic rectifier diode which injects rectified AC into the cathode. You can avoid problems from this by reverse-biasing this diode to more than the peak voltage of the heater, so try returning your virtual center-tap to around +20V instead of ground, but make sure there is low impedance to ground.
Sayonara
Old 19th July 2005, 01:46 PM   #5
kmtang is offline kmtang  Canada
kmtang's Avatar
Do you mind post the schematic?
Old 19th July 2005, 05:10 PM   #6
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
in euridice type of preamp,I prefere CCS for heaters,also elevated to at least 50 volts potential via divider;that divider must burn at least 2 mA to achieve good results and must be decoupled via minimum 10 micro.
try also to use smallest cap you can for cathode decoupling or ,even better, use NiCd instead of cathode resistor.
that's my opinion
look at http://choky.on.neobee.net for my WOT preamp
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
Old 20th July 2005, 03:40 AM   #7
Thanks for all your reply
The relay socket is marked Omron, bought just from the local electronic part store. It's well-made, and cramps the tube tightly.
All the Lundahls, hehe, I bought them years ago before I got married And I got some other which are enough for building a pair of mono block power amps. (maybe another or two more pairs of IT will be needed )
About the power choke concerns, I remeber in some books somewhere, the magnetic leak would be mostly in north-south direction (on the viewpoint of the picture above). I'm not sure how it'd actually be. For precaution (or my obsession), I wired the 2 chokes in oppiste direction. Also, I don't know if this helps or does the opposite. Changing the wiring is easy, I can do some experiment about that in the future.
Observed from the horn mouths, it seemed more hum on the left channel than the right. And that's the output transformer which is nearest to the choke. The difference is not very much though.
About the cathode bypass caps, is there any catch on their value? I've read that its low cut frequency should be at least 1 or 2 octaves below the rest of circuit can handle. I suppose it's for the phase stability?
I think the bottle neck of this portion should be the output transformer. It's a nominal 100H in the primary winding of LL1660, and a nominal 11Hz lowest frequency on 3k source impedance. Now it works with 5842 which Rp is about 1.6~1.7k, so I expect 6~7Hz on the bottom. If that's the case, 1 octave below is 3Hz, 2 is 1.5Hz. With 120R cathode resistor, the caps would be 470 & 1000 respectively (common values).
In the "original" design, this cap is 220, which represents 1 octave higher. However, its output transformer has only 15H in the primary winding.
hmm......
Anyway, I'll try more RC combinations on this.
For those insterested in the schematics, please see the attachment below. This is the current version, will surely be changed in the near future.
In the LPF portion, I took 2 sets of RC in the same value & use the feedback to tune the filter Q. This is derived from the books and was working good on my previous OP-based xover. However in this circuit, tuning the VR got little effect. I'm confused on this portion, will try more in the future.
Again, any thoughts or suggetions are appreciated.
I'll also keep updating for any changes & results.
Old 20th July 2005, 08:06 AM   #8
How careless I was!
Reviewing the schematics & data sheets, I found the primary winding of the output transformer ate 17.5V !! So the plate saw only 133V, no wonder the lowish current.
At this point, the tubes are barely awakened. I'm going to rebias them tonight.
Old 20th July 2005, 08:40 PM   #9
amirmk is offline amirmk  Israel
I really like those sockets, where can i get them?
Old 21st July 2005, 03:09 AM   #10
I think where you find an octal 8pin general purpose relay, you also find this socket. Omron PF083A is used in this pre amp. I also saw similar stuff in Digikey's catalog.
Last night I managed to have the following mods done:
1. Elevating the heater supplies by approx. 20V
2. Reducing the cathode resistor to 49R9
3. Reducing the RC filter's R from 2K to 330R
4. Adding Ultra-path caps
5. Replacing the grid stopper resistors to ferrite beads
6. Rewiring the input transformer to 1:1
7. Adding 2* 0.1R in each heater supply circuits.
2&3 above brought the operation point to 140~V on the anode, -1.25V bias & 25mA. The load line is slightly higher than the "original" 160V/20mA, & in the point of somewhat lower V & higher I. On the curves, it looked good.
It was 1am when I finished them, so no energy left to do a listening test.
With larger current draw, I found the ripples on power rails also enlarged a little. By DMM, I saw the output hum/noise was still 1.1~1.2mV as before. I know, this is bad
I don't fully understand how the Ultra-path works. According to TubeCAD Journal, the cap value is proportional to the amplication realized in the circuit & the cathode cap size. By this, I chose 33u as a trial, assuming I got 30 some of gain.
What would happen if this cap is over-sized? Over-compensation?
Anyway, I can't wait to have a listening to the newly mods.
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 06:42 PM
Its time to rehash the good ole "Which Cartridge" question duderduderini Analogue Source 82 11th August 2009 08:36 PM
the term "Time Symmetry" means....?? redrabbit Parts 1 13th February 2008 11:11 AM
Time for another round of "Criticise my Circuit"... err..I mean jerluwoo Tubes / Valves 11 13th July 2007 12:14 AM
Page generated in 0.29887 seconds (49.39% PHP - 50.61% MySQL) with 11 queries
