| diyAudio Sponsor | ||
Hello,
I would design gladly a 833a amp. Perhaps does someone have thereby experience or even a good connection diagram? I would use 845 a triode gladly as driver ( however I would do gladly without the two transducers in the preliminary stage). The whole is to become SE amp. The 833 anode voltage is to be operated and with -60V bias with a Raa of ~20k. it is around the 75 -100W to carry out in such a way with 3000V. MfG Dominic from Germany |
#2 | ||
However those crazy things turn out to be great most of the times! |
#3 |
Why use something as whimpy as a 833A when you could build One of These
#4 |
diyAudio Moderator Emeritus
#5 |
I will probably build this Amp. However with another driver, I think however I the Amp also times in the orginale will try out. Later then 845 drivers after Unison a S8, thus I have good experiences of sounded made ago.
It carries for instance 13W out (With small change which that heat the ECC concerns. )Unison S8 "Driver" 833a 75W Schematic Which hold you from orginal the circuit and/or from the idea the S8 as drivers to use in such a way. ... Gladly I would try also times the Wavac out 833 circuit. There does someone know which more drueber? ... MfG Dominic |
#6 |
I have some schematic's from Lancroft Audio, but they are not so perfect like i would want. I was thinking, building a very good set amp with a 300B and in place of a OPT, using an interstage trafo to drive the 833A, I was thinking of using the 300BXLS (powered at 472V and 120mA), drived by a µ-stage of D3A penthode and 27 triode (Attilla from Triode Dick) and in place of a beefy OPT, using of an interstage transformer. And i have an electron tubes book T1 from Philips, 1985 and would the TB4/1250 not been better than the 833A? The TB4/1250 looks better than the 833A, maybe little more stable?
I think that if you think, an 833A from Wavac, rated at 150w classA i think that it is most A2 driven, so sounds not so good. I have a schematic of the HE805 from Wavac, and the schematic diagram don't look spectacular high-end, more like an overkilled dissapointment (in technical therms if you study the schematic diagram)... |
| Amplifier using a 833A | Tekko | Tubes / Valves | 17 | 15th September 2009 01:02 AM |
| 833a SE Peak A.F. Grid Voltage | dominic_tollens | Tubes / Valves | 4 | 16th June 2008 10:08 AM |
| FS 833a tubes & caps | woody | Swap Meet | 2 | 18th September 2005 01:52 PM |
| tube 833a | wasibi | Tubes / Valves | 0 | 22nd April 2005 09:00 AM |
| 833a plate resistance ? | woody | Tubes / Valves | 8 | 5th August 2004 03:06 PM |
| Page generated in 0.15673 seconds (52.71% PHP - 47.29% MySQL) with 10 queries |
