hi,
1- I am looking for schematics (that are working?) for a pwr amp with 845 in push pull config. 100w out mostly in class A.
2- who knows what are the technical differences between the
p.p. and s.e. at such high power? who can drive difficult and variable loads like Acustat spk?
regards
williams
regards
williams
I have designed and built a few 845 PP amps.....
Have you thought of the 211???
When you say "mostly" Class A...You mean Class A for about most of the drive???? Before breaking into cut-off???
Pure push-pull Class A ...2 tubes??? You won't get 100 Watts....
Unless you go PP Class A2...now you would need one hell of an AMPLIFIER to drive that AMP
ANy more info you can provide....
Chris
Chris
