Debugging my Aikido - Page 3 - diyAudio
Old 5th July 2005, 09:40 PM   #21
diyAudio Moderator Emeritus
Bas Horneman's Avatar
moamps may be right on the mark about your transformers- saturating trannies throw out an amazing amount of field.
In that case I would expect the other channel to have the same amout of hum.
I suppose you've tried swapping valves between channels just in case its heater/cathode leakage
Yes..
planet10 needs your help:
Let's help Ruth and Dave
Old 5th July 2005, 09:41 PM   #22
moamps is offline moamps  Croatia
Originally posted by Bas Horneman
1/100 would be .1 sec/div right?
It's .01sec/div.
It only has one channel..that is Y right?
Yes.
or should it go on X..x says trigger..
The trigger should be set to internal, or to X input if the external trigger signal is used.
Milan
Old 5th July 2005, 09:46 PM   #23
It's .01sec/div.
So with my scope I would have to set it to 10m and then X10 ?
If I do that I get roughly one wave on my display!
The scope is a Tektronix T921
Ok..I had it on there but now I understand why it is there!
Thanx Milan..
Old 5th July 2005, 09:58 PM   #24
I am using the 12Volt part of the ECC99 i.e. 12 volt to pin 4 and 0 to pin5....but I have left pin 9 disconnected...should I have earthed it?
[edit] earthed it ...does not make one iota difference.....funny would at least expect to see something...
Old 5th July 2005, 10:06 PM   #25
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
If you listen and switch (only) the pre-amplifier off, does the hum go away immediately?
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 5th July 2005, 10:13 PM   #26
yes
Old 5th July 2005, 10:37 PM   #27
I don't know why..maybe because I've set the scope according to moamps...but now at least a part of the puzzle is falling into place.
If I measure now before the cap the sine wave is exactly the same as after the cap....!!!!
I've compared both channels with each other...I now seem to be able to test ripple on the b+ ...which I could not do before on the milliamp level....
all measurements are exactly the same except on pin 6 where the one channel is quiet and the other has one has hum..
b+ of 10mV peak to peak is not too bad is it? The ripple on the output looks to be around 1/2 that of the b+ ripple.
Old 5th July 2005, 10:52 PM   #28
SY's Avatar
OK, that's more sensible. Now you can chase more logical sources of ground loops and induction.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 5th July 2005, 11:07 PM   #29
B I N G O !!!!!
Don't know why I did not spot it before...it took a resistor from pin7 to loosen............ to spot that the other 100k resistor was connected to pin 6 instead of 7. (In other words the bottom 100k resistor was connected to pin 6 instead of 7..duh)
Old 5th July 2005, 11:08 PM   #30
Thanks ALL for helping me!
Now for the listening test
Debugging hiss in old receiver mashaffer Solid State 39 13th February 2012 03:34 PM
Debugging a Sony TA-1055 oddbjorn Solid State 19 24th October 2010 11:24 AM
Debugging a PIMETA headphone amp Atilla Headphone Systems 3 23rd April 2009 05:12 PM
Debugging TDA1541a DAC PSU FibCouple Digital Source 13 19th November 2008 01:59 AM
Debugging Quasi amp cm961 Solid State 7 3rd February 2004 11:54 PM
Copyright 1999-2017 diyAudio
