Debugging my Aikido - Page 2 - diyAudio
Old 5th July 2005, 08:26 PM   #11
diyAudio Moderator Emeritus
Bas Horneman's Avatar
I was able to look at the contruction pictures of your Aikido last night and I could not discern as to where the heater filament wiring ran in relation to signal and power supply in your construction. Is the twisted blue wiring filament? I thought I saw it sandwiched between two resistors at the socket.
Yes it is the blue twisted wire.
When I went to look at it again the link did not work.
Mmm are you sure? Here is the link to it
http://www.basenjes.de/tubes/images/aikido/index.html
Old 5th July 2005, 08:29 PM   #12
I think you are looking at the "safer version" example with 6n1p and 5687 tubes.
Correct
I wonder if 300V and 876 ohms (as in the first example he gives) isn't more appropriate for a 12sn7
You could be very right...I just knocked my stage together to prove the concept...I might build a better version up once I get it to quit humming. :-)
Old 5th July 2005, 08:33 PM   #13
Bas, how is the 1M resistor returned to ground? Does the ground return pass by anything that could induce hum into it?
I runs straight to earth...with theoretically no hum inducing wires...
Except maybe for this...the first cap after the rectifier is grounded on the exact same point...but what does that all matter because it is star earthing? Then again the currents might be pretty big whereas the current through the 1m is zilch...then again how does noise get through the 1m resistor to the cap?
Old 5th July 2005, 08:38 PM   #14
SY's Avatar
It doesn't look like a very good star from the photo, more like a small bus- if the 1M are the little light brown jobs, desolder the ground end, then reattach it at the other end of your mini-bus. Then take a look at some of the star ground photos in the Morgan Jones books to see the right way.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 5th July 2005, 08:41 PM   #15
Bummer..just lent the book out to a buddy.
Ok...will do...
Old 5th July 2005, 09:16 PM   #16
No difference after resoldering to the other end of the bus..I move the 1m'S for both channels...and the results were exactly the same....with the noise on the other channel being a little spikey but lower in amplitude and on the other channel the big sine wave or hum...
I'm going to switch around the filament supplies..each channel has its own transformer now..not visible in the current pics..because swapping tubes made no difference either.
[edit] swapped the filament supplies..no change whatsoever..
Old 5th July 2005, 09:22 PM   #17
moamps is offline moamps  Croatia
Hi Bas,
You twisted the R and L hot input wires, which isn't good. Use one twisted pair per channel. Even better, use shielded cables for an enviroment as noisy as yours appears to be.
All your transformers are saturated, IMO. The filament transformer is IMO overloaded with 5 tubes.
If you are using two transformers to get the B+ high voltage, the first one should have higher wattage and higher secondary voltage. The resulting power should be under 50 % of the VA rate of the secondary transformer.
About the scope:
Your measurements look like an RF signal. For measuring 50 or 100Hz signal, you should set the time base to 1/50 or 1/100 sec to see one circle or 1/1000 to see more circles in one widow.
Also, set the trigger to AC and appropriate source channel if your scope has more than one channel.
Also, you should take care not to induce noise/hum by connecting the measurement probe to DUT. Connect the probe ground to the star ground, and (if possible) connect the earth pin from your IEC connector to the star ground.
Milan
Old 5th July 2005, 09:27 PM   #18
SY's Avatar
It is a photo artifact or are the two output grounds tied together on opposite ends of the bus?
edit: moamps may be right on the mark about your transformers- saturating trannies throw out an amazing amount of field.
Old 5th July 2005, 09:29 PM   #19
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
Originally posted by SY
Dumb question for EC- if this were an oscillation causing the power supply to hummmmmm, then why doesn't it show up on the anode side of the output capacitor?
Good point. The capacitor is a short-circuit at RF, so RF should show up at either end. Trouble is, even at 100Hz, hum ought to show up at both ends, and it also ought to have a much more ragged waveform. Something's not quite right...
Bas: I suppose you've tried swapping valves between channels just in case its heater/cathode leakage? Another possibility is that the hum is induced by leakage flux from the mains transformers.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 5th July 2005, 09:33 PM   #20
Ok..did not know that..
I've added another one for the other channel..so the problem channel is feeding 2 tubes now.
1/100 would be .1 sec/div right?
Ok..have done so now..
It only has one channel..that is Y right? or should it go on X..x says trigger..
Debugging hiss in old receiver mashaffer Solid State 39 13th February 2012 03:34 PM
Debugging a Sony TA-1055 oddbjorn Solid State 19 24th October 2010 11:24 AM
Debugging a PIMETA headphone amp Atilla Headphone Systems 3 23rd April 2009 05:12 PM
Debugging TDA1541a DAC PSU FibCouple Digital Source 13 19th November 2008 01:59 AM
Debugging Quasi amp cm961 Solid State 7 3rd February 2004 11:54 PM
Copyright 1999-2017 diyAudio
