Gu50 output problems - Page 3 - diyAudio
Old 12th June 2006, 11:36 AM   #21
beamnet is offline beamnet  Netherlands
beamnet's Avatar
Send a message via MSN to beamnet
use an 6sn7 or two 6j5's
but i have plenty 7193-like valves for sale..
Bas
Old 20th January 2007, 05:19 PM   #22
2K for primary impedance isn't to low for Gu50, i know that the tube needs arround 5K.
have you made changes to the schematic after you solved the problems or the schematic is the final...
do you have a schematic for the power supply of the circuit???and for de output transformer
thanks
Old 20th January 2007, 07:50 PM   #23
Zibi is offline Zibi  Poland
http://www.tubefreak.de/
http://www.goldenmiddle.com/english/trans.htm
Old 21st January 2007, 12:53 PM   #24
beamnet's Avatar
There is no former there that would survive the gu-50
Im have used beard p-100 output formers.
The other link doesn' have a schem
I would advidse the schem i gave. It is simple as hell and allows for easy mods. i have ccs on the tail now and various other tweaks.
The ps:
schematic
Good luck!
Old 21st January 2007, 08:28 PM   #25
adishor_2005 wrote: 2K for primary impedance isn't to low for Gu50, i know that the tube needs arround 5K.
http://www.goldenmiddle.com/english/trans.htm :
5k/8ohm 40W Recommended tubes: 6P3S, 6L6, 6S4S/2A3, 300B, 6550, EL34, 6P41S, 6P36S, 6P45S, KT66, KT88, G807, GU50, 6R3S, GU19
6k/8ohm 50W Recommended tubes: RB300-3CX, KT66, KT88, 6550, GU50
http://www.realaudiotechnika.bacska.hu/parts.htm :
PPP Raa 2K5/8ohm 120W PPP GU50 (AB 120W RMS!)
Old 21st January 2007, 09:17 PM   #26
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
What is PPP? 2 tubes in parallel?
One pair of GU-50 gives 120W in PP mode with 6K CT transformer.
Actually, it was a LS-50 stolen from WW-II enemy by Soviet engineers. It was designed by Telefunken ray pentode, after the war they used to produce EL152 that was cheaper than military version LS-50 and Soviet clone GU-50, but anyway it was expensive because of materials and technology. Rated for 40W plate dissipation it could survive more because of specially treated nickel plate that could glow red without a harm for a tube.
http://www.tubecollector.org/main/ls50.jpg
http://www.wiwitubes.com/pic/tube/TFKel152.jpg
http://www.tubecollector.org/main/r-gu50.jpg
I was intended too keep silence about it, because ePay reacts fast on publications on forums...
The Devil is not so terrible as his math model is!
Old 21st January 2007, 10:22 PM   #27
parallel push-pull
120W@6k load O.K. - but what about anode voltage?
800V? 1kV?
Old 21st January 2007, 10:49 PM   #28
Wavebourn's Avatar
parallel push-pull
800V? 1kV?
750 in my amps.
Old 22nd January 2007, 03:23 PM   #29
Pretty high.
Old 22nd January 2007, 07:15 PM   #30
Wavebourn's Avatar
Just enough for an excellent sound.
Gu50 cristelu2006 Tubes / Valves 13 18th November 2009 10:29 PM
IR2110 output problems G4ME Class D 7 15th January 2008 04:25 PM
41hz Amp 4 Output Problems emu Class D 1 20th December 2007 09:04 PM
Gu50 Set ? pwan Tubes / Valves 3 22nd April 2007 04:15 PM
Audio schematics for GU50 ???? felixx Tubes / Valves 16 8th February 2007 05:19 AM
Copyright 1999-2017 diyAudio
