211 amp PSU question
Old 1st July 2005, 08:08 AM   #1
trancy is offline trancy  Slovenia
trancy's Avatar
Default 211 amp PSU question
I found this schematic, and I want to build that beatiful baby....so, can I use PSU for both channels, and if not, what should I change??
http://tinpan.fortunecity.com/saints...mer/211-se.gif
lp
trens
too much is just enough
Old 1st July 2005, 11:29 AM   #2
On Hiatus
SY's Avatar
You'll need to redesign the PSU for double the current at each winding. That means a transformer with double the current rating, using rectifiers with double the current capacity, doubling up the warmup control 5AR4, and modifying the filtering (bigger C, bigger L, more current capacity for the L) to drop the ripple back to the single PSU values.
It's not trivial, but it could be done. Given how exquisitely sensitive SET is to the power supply, you want to do this carefully and systematically to avoid burning up money needlessly.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 4th July 2005, 10:24 PM   #3
cpu_bach is offline cpu_bach  Japan
The referred circuit looks a Japanese one and I notice particular power transformer which was once popular in the market. The high voltage windings have enogh current capacity to support two channel amplifiers. Also, 5AR4 and choke coil can work for two channnels. Thus what you additionally need is another filament supply (10.5V) which is not shown in the drawings.
I build a similar amplifier more than 20 years ago and it works pretty fine up to now.
Good luck!
Old 5th July 2005, 05:54 AM   #4
trancy's Avatar
so actually goes 100mA on channel at 900V and +/- 30mA for 6SN7`s...is that enough??
lp
trens
Old 5th July 2005, 09:06 AM   #5
I cannot follow your calclation, but 900V line consumes around 80mA per channel and 10mA or so for the lower +B line. Thus, you do not have to worry about the power supply capacity.
Old 5th July 2005, 12:04 PM   #6
trancy's Avatar
thanx .... i get it...
211 amp PSU questionHide this!Advertise here!
newbie with input tran. question and wiring question imo Solid State 0 18th January 2006 10:10 PM
Capacitor Question /question on cap TunaFish Parts 14 12th January 2004 02:23 AM
PS question - tformer question actually breguetphile Chip Amps 2 30th May 2003 01:29 PM
old speaker question, bullet midrange question & link to speaker project wallijonn Multi-Way 10 5th November 2002 06:03 AM
