se 6c33c or se el34 schematic
Old 29th June 2005, 06:59 PM   #1
karma is offline karma  Canada
karma's Avatar
Wink se 6c33c or se el34 schematic
anyone have any simple schematic's to share. i allmost have everthing ready well allmost everthing.
i would rather go with the el34's
thanks.
Old 29th June 2005, 08:44 PM   #2
WALTER BURKHARD is offline WALTER BURKHARD  Finland
WALTER BURKHARD's Avatar
Default se 6c33c or se el34 schematic
se 6c33c se schematic
Old 29th June 2005, 08:48 PM   #3
Default se 6c33c se schematic
Old 29th June 2005, 09:22 PM   #4
karma's Avatar
thank's
Old 30th June 2005, 08:40 AM   #5
plovati is offline plovati  Italy
Default Leclerc (Audiophile) EL34 SE
http://www.audiofanatic.it/Schemi/Ti...34SE_12AX7.jpg
Was published on the Audiophile french magazines by Michel Leclerc.
IMHO great schematic, simple good performances, cheap.
Power supply use only Poli CAP, no electrolitycs.
Piergiorgio
Old 30th June 2005, 10:20 AM   #6
Bas Horneman is offline Bas Horneman  Netherlands
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Here is a simple good sounding schematic (Not optimized for max power) I used the stuff I had in my partsbin.
http://www.basenjes.de/tubes/jbsel34.htm
If you can see the speaker cone move...it's not hifi.
Old 30th June 2005, 11:59 AM   #7
Alastair E is offline Alastair E  Wales
Alastair E's Avatar
Default 6C33C-B Schematic, and Tx winding data
Just thought I'd add my two-pence-worth,--Take a look at the scheme halfway down this thread--
http://www.diyaudio.com/forums/showt...0&pagenumber=4
Maybe a little complicated in comparison to the others, but works well, with good dynamics.
As is, sounds pretty good, but Ive since altered it slightly by using 6SN7 at driver Mu top half and 6SL7 strapped parallel for bottom half of Mu driver--Sounds great now...........
The Tx winding data is there too if you are feeling adventurous!
Das Beste Oder Nichts
Old 2nd July 2005, 01:44 AM   #8
karma's Avatar
well i found a power tranny to start the project but its a little small
to use with the 6c33c so im going to try bas horneman's se el34.
most of the part's like the Russian oil caps and military grade caps i can get from the tube store. ill try to stay with the same part's to see how it worked for you.
thanks..
Old 2nd July 2005, 08:48 AM   #9
Good luck!!! There is room for improvement ofcourse. But building it is a lot of fun, and I thought it sounded great. You can always tweak a little afterwards. For instance the grid stopper on the 6n1p is a little high..maybe a 100R gridstopper or even none would sound better. And maybe a little decoupling cap after the 15k voltage dropping resistor. Ofcourse the whole c4s is not that essential. You could just substitue a 33k resistor. But the C4S makes it more linear and quieter.
On 90dB speakers there is a little humm if you listen carefully with just the one choke and cap values.
It might need a preamp as well...so you could leave out the pot ...just solder in a 47k or 100k resistor...
Old 2nd July 2005, 03:50 PM   #10
protos is offline protos  Greece
protos's Avatar
Default Re: 6C33C-B Schematic, and Tx winding data
I am also in the process of designing a 6c33 amp with a few twists- probably a type of monkey/drd with two 6c33 opt in series per channel for regulating distortion cancellation.Anyway I wanted to refer to your power measurements.You must mean you get 30W peak and not RMS from your amp.I have played various simulations on tubecad and there is absolutely no way to get more than 16/17W RMS from one 6c33 tube and second thd is already quite high.
se 6c33c or se el34 schematicHide this!Advertise here!
6C33C schematic Hesky Tubes / Valves 79 16th June 2013 07:34 PM
EL34 schematic confusion navin Tubes / Valves 620 15th November 2010 07:51 AM
Can this schematic work? 6N6P driver with 6C33C-B OTL Koifarm Tubes / Valves 13 13th April 2010 04:28 AM
Schematic for GU-50, EL34, 6J32P ??? Dxvideo Tubes / Valves 3 24th September 2007 11:51 AM
Copyright ©1999-2017 diyAudio
