6e2 Magic eye datasheet
Old 27th June 2005, 04:30 AM   #1
Silver Stealth is offline Silver Stealth  Australia
Silver Stealth's Avatar
Default 6e2 Magic eye datasheet
Hi
Does anyone have a data sheet for a 6e2 aka Magic Eye tube? I'm trying to work out how to increase the visual dynamic range of the magic eye tube on this 6H30 preamp I recently purchased off ebay from HK. It's wired in like a "VU Meter" so the bars dance around as the music plays - way cool!
At steady state (no input signal) the bars are already 50% lit up.
I've looked for a data sheet at the usual suspects (Duncan Amps, Google etc) with no avail.
I have the schematic but it was too big to attach here - if anyone wants a copy just PM me.
Great sounding preamp by the way (buckets of drive and dynamics) and inexpensive to make. Board off ebay was about $100US delivered. Transformer and stepped attenuator added about another $150US and I have current recycled an old box for the chassis
Cheers!
Kendrick
Old 27th June 2005, 08:49 AM   #2
Simpleton is offline Simpleton  Portugal
Could it be a 6E5 instead?
Old 27th June 2005, 09:02 AM   #3
Hi
It may well be like it, but both the ad and the circuit diagram show it as a 6e2....good thought though!
Cheers!
Kendrick
Old 27th June 2005, 12:23 PM   #4
I say this because running 6E2 through Duncan's TDSL, it shows a pentode.
This is a neat tube, i have one i hooked up once.
Let me check a link and i'll post there, ok?
Old 27th June 2005, 12:58 PM   #5
http://web.telia.com/~u87127078/eyes/index.htm
http://web.telia.com/~u87127076/
Old 28th June 2005, 05:55 AM   #6
Thanks for the very useful links - I never realised there was such a variety!
My 6e2 looks quite similar to the EM840 type having the two vertical bars one above the other.
Is it normal to have the bars 50% lit with no signal? I would have thought not.
Cheers!
Kendrick
Old 17th November 2005, 01:41 PM   #7
Andypairo is offline Andypairo  Italy
Andypairo's Avatar
If you are talking about Lite Audio LS32 I have the same preamp and it behaves the same way.
Do you find that the tubes tend to be microphonic? Mine are Sovtek 6H30 .... and seem to be terribly microphonic.
Cheers
Andrea
I don't believe in audiophile components - except when I can get them at frugal-phile(tm) prices
Old 20th November 2005, 08:27 AM   #8
Andypairo's Avatar
Here is the schematic:
I'm also a bit dubious about the output cap, that seems quite small...
Cheers
Andrea
Old 20th November 2005, 08:35 AM   #9
bigbulb is offline bigbulb  Canada
The 6E2 is much closed to EM87 and EM84 in its characteristic.
Here's another level indicator using 6E2:
http://www.audiohobbyist.com/projects/magiceye.htm
BigBulb
Old 28th November 2005, 12:47 AM   #10
johnmarkp is offline johnmarkp  United States
Two questions on this preamp. How big should the caps be for the output? Also can the gain be lowered easily?
6e2 Magic eye datasheetHide this!Advertise here!
Magic Gu15 VanguardVillage Tubes / Valves 7 18th June 2014 03:09 PM
The Magic of a Name 7N7 Tubes / Valves 9 1st December 2007 05:58 PM
Naim magic box ash_dac Everything Else 2 17th July 2006 12:30 PM
Magic Capacitor tenderland Solid State 23 22nd June 2006 07:39 PM
TAD - the magic drivers? amo Multi-Way 4 12th May 2004 04:49 AM
Copyright ©1999-2017 diyAudio
