Another linestage......
Old 26th June 2005, 03:41 PM   #1
kianbach is offline kianbach  United Kingdom
Default Another linestage......
Will THIS work and if not why not?
Old 26th June 2005, 03:52 PM   #2
On Hiatus
SY's Avatar
The plate of the first stage is at AC ground.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 26th June 2005, 04:01 PM   #3
Explain please I'm a newbie
Old 26th June 2005, 04:58 PM   #4
moamps is offline moamps  Croatia
The anode resistor on the input tube is missing.
Milan
Old 26th June 2005, 06:01 PM   #5
What sort of value should I use?
Is there a formula to work it out apart from Ohm's law for dropping voltage?
I've got some 6k8 and 10k resistors.Would either of these do?
Old 26th June 2005, 06:36 PM   #6
On Hiatus
SY's Avatar
I don't mean to be rude, but you're asking a lot of questions about arrows and you haven't yet defined the target. What are you trying to accomplish? Gain, source Z, load, distortion, signal-to-noise...?
Old 26th June 2005, 06:52 PM   #7
Well,I've got an SRPP 6SN7 linestage atm and am looking for more gain and/or a different sound.A few months ago I tried Joel's 12AY7/6SN7 circuit but with ecc81 and 6N7 and liked the sound of it but was thinking of having 1/2 the B+ for the 1st stage and direct-coupling between stages,hence this sorry attempt at designing my own.I was hoping someone could point me in the right direction,I need to drive a SRPP 6SN7/2A3 SE power amp.
Old 26th June 2005, 08:10 PM   #8
..... I tried Joel's 12AY7/6SN7 circuit but with ecc81 and 6N7 and liked the sound of it but was thinking of having 1/2 the B+ for the 1st stage and direct-coupling between stages.....I need to drive a SRPP 6SN7/2A3 SE power amp..
Use 300V B+ for ECC85 (omit OA2 and 0.1uF),
Va=150V, Ia=10mA, Vgc=-1V,
then
Rc=Vgc/Ia=100ohm (in your schematic 390ohm),
Ra=(Vcc-Va)/Ia=150/0,01=15kohm (dropper in your schematic).
Milan
Old 26th June 2005, 09:29 PM   #9
Thanks for your help.Will the second stage be OK as is or do I need to change anything?
Old 28th June 2005, 01:11 PM   #10
Well it's built and running!Sounds nice,plenty of gain,Drives my 2A3SE no probs.Ear bleeding volume from my Lowther Acoustas.
Values as follows::
B+ 300v
Ecc85 anode R = 15k
Ecc85 cathode R = 220r
6N7 cathode R = 23.5k(47k x 2)
total current draw 25mA from a 100mA tranny.
NICE!
Will post Picks soon but it looks rough as it's on my experimantal/Frankenstein chassis.
Another linestage......Hide this!Advertise here!
C3M linestage costa23 Tubes / Valves 15 23rd August 2009 08:53 AM
C3m linestage bequerel Tubes / Valves 32 14th April 2009 06:03 AM
48V B+ linestage hirafu_boarder Tubes / Valves 24 11th May 2008 05:57 PM
My 6S19P Linestage sorenj07 Tubes / Valves 4 12th April 2008 06:21 PM
An almost DIY 6DJ8 Linestage JesseG Tubes / Valves 37 17th November 2007 11:43 PM
