Power supply for Single Ended Amplifier
Old 25th June 2005, 10:15 PM   #11
ErikdeBest is offline ErikdeBest  Switzerland
mostly thinkerer
This is a nice discussion about the influence of power supply in the amp's sound! Have any of you tried a regulated PS? And what kind of regulation? Vantages, disadvantages...or why would you do/don't do it?
Old 25th June 2005, 10:17 PM   #12
kianbach is offline kianbach  United Kingdom
I've used a tube regulated power supply in my preamp and it makes a HUGE difference but then again i've used a pair of big chokes but the sound is more open since i put the vr tubes in...
Old 25th June 2005, 11:47 PM   #13
kmtang is offline kmtang  Canada
kmtang's Avatar
I used tube regulatred power supply for my Matissee line amp. I then modified it so that it is switchable between tube regulator and LCLC filtering only. The LCLC sounds more sweet and smooth.
Of course, the last cap in the PS have big impact to the sound.
Johnny
Old 25th June 2005, 11:54 PM   #14
sklimek is offline sklimek  United States
sklimek's Avatar
If one does decide to go the CLCLC or LCLC and wanting a surface mount this James choke can provide it in one package.
It does 2.5H + 2.5H or wire it in series for 10H, not hard to look at either...
http://euphoniaaudio.netfirms.com/ea...5a40c700cbdf8d
Old 25th June 2005, 11:55 PM   #15
RE 604 is offline RE 604  Germany
RE 604's Avatar
Hello ,
I always use tube - regulated power spplies in my single ended amps and for me , it sounds best with one supply for one channel .
In the picture you can see two supplies with EZ 80 , EL 86 , EF 80 and 85a2 .
Regards , Alex .
No reason to get excited : Jimi Hendrix .
Old 26th June 2005, 12:46 AM   #16
ThorstenL is offline ThorstenL  Germany
Previously: Kuei Yang Wang
Konnichiwa,
I tried all sorts of approaches and I find that you need to consider amplifier and PSU as one and tune them together. Do that and you can get very good results from any configuration that gets the basic right.
Sayonara
Old 26th June 2005, 05:13 PM   #17
Here's the schematic for the PSU in my 6SN7 linestage exactly as built.It's amazingly clean and detailed.Next job is regulated heater supplies
The 0.047uF cap should have been drawn AFTER the OD3 pair.DOH!!
Old 26th June 2005, 05:22 PM   #18
Here's how it should be
Old 27th June 2005, 02:42 PM   #19
kmtang's Avatar
Hi Slimek,
I am just wondering why you employed a RC filter in the last stage of your power supply. I added a RC filter of 250-ohm 100uF for the last stage which forms CLCRC so that I could lower the B+ from 455V to 430Vdc for my 300B SE amp.
With this change, my 300B amp sound rather differently. It has more sweet and detailed sound.
Old 27th June 2005, 03:22 PM   #20
If you mean the 5k pots before the 6SN7 regulator then I wanted to be able to tweak the voltage from 300v to 225v to use different tubes,eg:6SN7/5692 or it also works with 6SL7 but gives a lot more gain.The extra PIO caps before the anodes also make the sound a lot smoother and detailed.Bass is incredible.I tried it without the 6SN7/32uF and it sounds better with than without.
Power supply for Single Ended AmplifierHide this!Advertise here!
single-ended power supply (12V) based active crossover r_s_dhar Car Audio 8 15th April 2011 09:44 PM
power supply for my single ended amp jhaible Power Supplies 23 2nd November 2006 09:51 AM
High Power Single Ended Amplifier Club Unison845 Tubes / Valves 4 27th April 2004 02:32 PM
