diyAudio Sponsor
Old 19th March 2010, 09:20 AM   #11
Shoog's Avatar
I have used a toroidal as a parafeed interstage. It worked and sounded good, but I needed to push 30mA through the driver just to get the top end up to about 35Khz. To much interwinding capacitance.
It works but not recommended.
Shoog
Old 19th March 2010, 01:16 PM   #12
piero7 is offline piero7  Italy
piero7's Avatar
Originally Posted by dice45 View Post
Matt,
Sowter 9050 or LL1660PP: It depends what you want to achieve.
For the 6SN7 (R_p= 7k) the Sowter 8650 or 9050 certainly is better suited as the tube should face a load of atleast 15k.
With the 8650 you get 185R (+ secondary DCR) as output resistance, with the 9050 417R plus sec.DCR.
I am not sure if the 6SN7 is the right choice if you want to use the LL1660; it only has a stepdown turns ratio of 2.25 in PP to line out mode. You end up at about 3k output resistance then. Better use a 5687 or a juicy 12B4A to drive the LL1660.
Sonics: i haven't heard either in my system, but i heard the LL1660 in Thomas Mayers system and liked it very much; Thomas even recommended the thing for single-ended mode.
Sowter makes any custom job you want, Lundahl does not. But in general the sonic reputation of Lundahl is considerably better (exceptions exist).
I have decided to use the LL1660 PP for my preamp project; i will use a 12B4 to drive it and i guess the Lundahl driven by the right tube will be dramatically better than the Sowter. Moreover, it has way higher safety margins concerning isolation voltages. The only Sowter i considered was the 9111 but this baby has to be used in parafeed mode which i want to avoid: parafeed needs a cap to block the CD; this is a coupling cap. I strive to avoid coupling caps in my system.
Could you post schematic diagram of your preamp with 12B4+1660 please?
Old 19th March 2010, 07:11 PM   #13
Gordy is offline Gordy  United Kingdom
piero7, please note that you have quoted a message from 14th September 2002!
Good luck with that!
Old 20th March 2010, 10:42 AM   #14
piero7's Avatar
thanks gordy I didnt notice it was so old
GB: Sowter 10K:10K Input Transformer luvdunhill Group Buys 159 26th February 2012 02:22 AM
Sowter's Radford transformer theoldtrout Tubes / Valves 0 28th September 2008 11:45 PM
Iron: Sowter, Lundahl, Magnequest tubesguy Swap Meet 5 7th June 2008 08:54 AM
Problems Lundahl LL1660 and 6c45 to 6c33 Triode!Need help! barossi Tubes / Valves 6 29th October 2003 10:08 PM
Raven using Lundahl instead Sowter Maurizio Tubes / Valves 2 17th September 2003 04:11 PM
Page generated in 0.16049 seconds (38.59% PHP - 61.41% MySQL) with 11 queries
