Very high output level!
Old 14th June 2005, 05:28 PM   #1
Matthewong is offline Matthewong  Malaysia
Default Very high output level!
I've a problem regarding to my new pre-amp. My pre-amp is using 2 6072 EH tubes and the problem is how can I lower the output level? The output sound is very high, I just can only turn the volume control to around 8 o'clock and the output sound is already very high. I hope that you guys and help ,e to solve this problem. Thanks
Old 14th June 2005, 05:30 PM   #2
On Hiatus
SY's Avatar
A few details might help. Schematic, for a start.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 15th June 2005, 07:10 AM   #3
ray_moth is offline ray_moth  Indonesia
diyAudio Moderator Emeritus
ray_moth's Avatar
A question to ask is, for what main amp sensitivity was your preamp intended? Is it compatible with your amp? If, for example, you have a Leak or Mullard-designed main amp, then the chances are that the output signal of most preamps would be much too high.
Old 15th June 2005, 04:02 PM   #4
Below is the schematic. I've using a lot of power amp, from AMC to Audioloab to audio research, all the same, very high output level. I hope that you can help me to solve this problem. Thanks
Old 15th June 2005, 05:12 PM   #5
Schematic
Old 15th June 2005, 06:21 PM   #6
On Hiatus
SY's Avatar
There's an inverting gain stage as a line amp. I can't read the numbers on the schematic too well, but it looks like you've got a cathode resistance of roughly 1K. 125K on the plate. With a plate resistance of 25K and a mu of 44, the effective plate resistance is about 70K. So the gain will be something like 27-30. That's about 29dB, a lot of gain.
You can go two routes: easy and non-optimal, or hard but optimal. The former way, just pad down the input. The latter, redesign the stage for much less gain, a non-trivial project.
Old 16th June 2005, 09:19 AM   #7
Frank Berry is offline Frank Berry  United States
Frank Berry's Avatar
You can always connect the grid of the cathode follower output stage directly to the volume control and eliminate the gain stage.
Frank
Old 16th June 2005, 12:39 PM   #8
On Hiatus
SY's Avatar
Nope, it's not that simple. If you do that, the DC conditions for the CF will be unsatisfactory. Conceptually, it's a fine idea, but implementing it will involve putting a DC bias string and a coupling cap at the input of the CF. That's not horribly difficult, but it will take some design effort to do it right.
Old 16th June 2005, 12:56 PM   #9
Why not just change the value of the cathode resistor?
No cap needed on the grid.
Frank
Old 16th June 2005, 01:02 PM   #10
On Hiatus
SY's Avatar
That's exactly the sort of thing that has given cathode followers a bad reputation. Drop that resistor and the distortion goes sky high. The drive capability goes away, too.
To do a proper cathode follower, you need some room under that cathode. Big resistor with a lot of drop or a current source with sufficient compliance. That means cap coupling and biasing up the grid or putting in a negative rail and running a resistor or current source to it.
Nontrivial.
Very high output level!Hide this!Advertise here!
JBL Sub high level input only Dr Moreaux Subwoofers 5 22nd April 2007 04:04 AM
Need High level, high pass crossover for 250watts Anthrax Multi-Way 0 21st January 2007 04:34 AM
lesser of two evils, high level -> line level, digital volume control mazurek Solid State 3 19th November 2006 01:25 AM
Output from FM tuner too high level klitgt Analog Line Level 4 17th November 2005 07:27 PM
Using high level in on sub amp? squidbait Subwoofers 14 30th January 2004 12:06 PM
Copyright ©1999-2017 diyAudio
