6c33c PSE
6c33c PSE
Old 12th June 2005, 02:26 PM   #1
mark_titano is offline mark_titano  Italy
Default 6c33c PSE
A friend of mine wants to build a 6c33c pse. We are thinking that, due to the high grid current (even when the grid is far from 0V) and the high input capacitance, a good solution should be a cathode follower direct coupled to the output tube. We've tried to design something that could even solve the bias problem for the power stage. Look at the result. I'm sure that we neglected something and this is the reason why I'm posting the scheme here and asking for your help.
Thankyou guys
Mark
Old 12th June 2005, 03:45 PM   #2
Yvesm is offline Yvesm  France
Yvesm's Avatar
Hi Guys !
Nothing scratched my eyes at first.
I really do like the first stage with its CCS load and 400v B+, not to tell about the absence of cathode bypasses.
Heu... and what about simply bias each 6SN7 from a (adjustable) tap on its cathode resistor.
This should introduce some bootstrap releiving load from the first stage by practically hiding the grid leak resistors.
Just to chat.
Yves.
Old 12th June 2005, 04:05 PM   #3
moamps is offline moamps  Croatia
Hi Mark,
Does the driver stage (6072) have enough gain to drive the output triode?
Isn't current from +B3 400mA?
Milan
Old 12th June 2005, 04:40 PM   #4
Hi Yvesm, Hi Milan.
Milan you are right...200mA for each 6c33 so 400mA in total. The 6072 with its hybrid load can provide the full mu because the current is stable and the load line straight. I think that a better solution is to change the R12 with two red leds. However...I think that with 3Vpp on the input the driver should be able to produce a 140Vpp swing. Because the amp will be two monoblock, we are thinking to change the 6072 with an ecc88 and use the second half as a common cathode preamp to make the sensibility higher.
Yvesm, what do you mean when you said: "Heu... and what about simply bias each 6SN7 from a (adjustable) tap on its cathode resistor.
This should introduce some bootstrap releiving load from the first stage by practically hiding the grid leak resistors."?
My english is not so good, could you explain it better please?
Mark
Old 12th June 2005, 05:01 PM   #5
Yvesm's Avatar
Mmmh, when a Frenchy speaks to an Italian using english
I mean, just return the grid leak resistor of the 6SN7 to a tap on its cathode resistor.
For example, replace R5 by an 1K in serie with a 12K and tie the low end of R11 at the junction.
The 1K being at the cathode side and the 12K at the -200 side.
This places some positive feed back to the grid and greatly increases the input impedance because the low end of R11 is somewhat 'driven' by the cathode voltage swing.
Yves.
Old 12th June 2005, 05:50 PM   #6
Ok...I've modified the schematic.
Looks as you expected?
Old 12th June 2005, 05:58 PM   #7
Yvesm's Avatar
Yes, that's that !
Certainly C1 and C2 could be lowered a bit.
Yves.
Old 12th June 2005, 06:31 PM   #8
That's not a problem. Now we could try a soviet teflon 0.1 cap
Now I have to think to the power supply. My friend has already build a 6c33 pse and has two transformers that can provide 235Vac/500mA, 335Vac/100mA each. Do you think is possible to create a virtual gnd and a +/-200V from the 335Vac secondary and even obtain the 400V for the driver stage?
Mark
Old 12th June 2005, 08:05 PM   #9
tubetvr is offline tubetvr
What high grid current? 6C33C this tube doesn't have high grid current and ~100kohm as gridleak is no problem to use, if you measure noticeable grid-current your tubes are probably faulty!
High capacitance? depends what you mean but due to the low mu the total Miller capacitance of a 6C33C is not much higher than tubes like 300B.
However if you want to have high bandwidth and using 6C33C in PSE I can understand the idea about using a CF to drive 6C33C but then I would probably use a 12BH7 or something similar, not just a 6SN7.
Regards Hans
Old 12th June 2005, 10:12 PM   #10
Hi Hans.
What I mean is that every power tube have a small grid current. The class A manual approximation is only an approximation. Have you ever tried to use this small current to polarize small signal tubes? You can connect the cathode to gnd and a high value leak resistor from gnd to grid...and it works.
Probably due to its high transconductance, the 6c33c grid starts often to conduct before the 0V grid bias. And this point changes during the tube's life.
The miller capacitance of a 300B is not really low. I suspect that this neglected aspect ( with the fact that even in full class A the grid current is an issue...) is the reason why simple set two stage with 300B sound so slow and with bass booming! Simply the load collapses at low frequency.
You are right for the cathode follower. I'm redrawing that stage with the ecc99.
What about the voltage amplifier? I'm thinking to use an ecc8 and use one half in front of the hybrid srpp.
Mark
6c33c PSEHide this!Advertise here!
6C33C-B. PP or SE ? Predator864 Tubes / Valves 475 4th June 2013 06:06 AM
6C33C-EB / 6C33C-EV extended life ? ger56 Tubes / Valves 2 14th October 2007 06:54 PM
WTB 6c33c-b woody Swap Meet 0 20th September 2005 08:36 PM
WTB 6c33c-b woody Swap Meet 0 8th September 2005 03:41 PM
6c33c-b Se morfeas Tubes / Valves 3 19th November 2004 12:55 PM
