diyAudio Sponsor
Old 12th June 2005, 11:47 AM   #1
Default 75% of rated max. current too high?
I am working on a tube preamp. I really love the AZ1 rectifier tube. This has a rated max. current of 100 mA.
Would you consider a constant load of 75 mA to be too high (i.e. excessive tube wear)?
Thanx!
Old 12th June 2005, 02:01 PM   #2
Alain Dupont's Avatar
bequerel,
Looking at the docs... Philips AZ1 - 1953
http://www.mif.pg.gda.pl/cgi-bin/vs4.pl
2*300volts 100mA
2*400Volts 75 mA
2*500Volts 60mA
In the case of <=300Volts 75mA is correct.
Regards.
Old 12th June 2005, 02:09 PM   #3
Thanks a lot, Alain! I was not aware of that the max. current was dependent on the voltage. (The link does not work, by the way.)
Thanx!
Old 13th June 2005, 12:07 PM   #4
bequerel,
The right link is:
http://www.mif.pg.gda.pl/homepages/frank/vs.html
search for AZ1
Regards.
Alain.
Old 13th June 2005, 12:22 PM   #5
Thanks, that works.
Thanx!
High voltage, high current super regulator, possible group buy peranders Group Buys 54 2nd June 2009 09:43 AM
high current vs high voltage power Clipped Car Audio 28 19th April 2007 06:06 PM
Source for a high quality y-rated film cap? Colescuttle Parts 1 13th January 2007 07:50 PM
6BY5 High Voltage & High Current Choke Input Design P.S. snoopyma Tubes / Valves 7 28th June 2006 01:32 PM
high volt/high current DIY home PS. deepanger Solid State 24 13th December 2002 12:17 AM
Page generated in 0.11996 seconds (54.11% PHP - 45.89% MySQL) with 10 queries
