diyAudio Sponsor
Old 10th June 2005, 05:42 PM   #1
Default tube pre-amp
I've built a tube pre-amp using 2 6sn7gts. I'm facing a very big problem now and hope that someone out there can help me. My pre-amp will come out humming aound, and have tried a lot of methods, but still there the humming. Can anyone tell me how to solve it?
Old 10th June 2005, 05:46 PM   #2
Do you have it's schematic, together with the PSU? it would help a lot.
Could be a faulty ground connection, filaments(?), ....
Old 10th June 2005, 06:36 PM   #3
SY's Avatar
There's a 99% chance that you've got a ground loop.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 11th June 2005, 04:47 AM   #4
kmtang is offline kmtang  Canada
kmtang's Avatar
Do you use DC for the filament? Also, you need to raise the potential filament supply to approximately 80-100V in case the last stage is a cathode follower.
Of course, the ripple level of the B+ could induce in lot of hum as well.
Please post your schematic and picture of your amp so that we could find whether there are anything we could see.
Johnny
Old 12th June 2005, 04:54 PM   #5
Default Humming
Thanks all of you. I've tried everything I could to reduce the hum, but the hum still there. From voltages to ground looping, everything I've tried. First I thought It was bacause the heater voltage. But after some modification, the hum only reduce a little bit, the hum is still there. I've attached the schematic, hope you all can help me. Thank you.
Old 12th June 2005, 05:14 PM   #6
sklimek is offline sklimek  United States
sklimek's Avatar
Default Re: Humming
Schematic? Sometimes when you attach a file and 'preview' before sending you need to re-attach the file before sending.
if that's what happened.
Stan
FS tube tuner, Active filter kit, tube amp, amp3 Josephjcole Swap Meet 9 20th July 2007 04:05 PM
SS or tube voltage amplifying stages in an amp with tube output? ray_moth Tubes / Valves 14 4th July 2007 03:09 AM
need diy tube preamp (line-stage) recommendation and general tube advice Musiclover4 Tubes / Valves 15 24th November 2005 01:19 AM
tube driving the same tube - whats the collective word? zobsky Tubes / Valves 3 13th June 2005 06:47 AM
Page generated in 0.12087 seconds (54.19% PHP - 45.81% MySQL) with 11 queries
