Regulated Dc Question
Old 10th June 2005, 10:43 AM   #1
kianbach is offline kianbach  United Kingdom
Question Regulated Dc Question
Hi,I'm building a 6sn7/2A3 SE amp and was wondering if it's possible to split the filament supply after the bridge and cap to use 2X LT1086 as current regulators for the 6sn7's.Could anyone help me out with a schematic.Thanks in advance
Old 10th June 2005, 03:43 PM   #2
Gluca is offline Gluca  Italy
Gluca's Avatar
That's what I drafted (the scan is not so clear ...) today for a preamp I am planning to build. You will need to adjust the 0,5R sense resitors to feed properly your tubes. I think it will work ...
Are you going to series connect the tubes or what??
Ciao
Gianluca
Old 10th June 2005, 10:18 PM   #3
I was planning on using a toroid with 2 0-9v windings .One for each valve(6SN7 linestage).
Old 12th June 2005, 03:07 PM   #4
Gluca's Avatar
Well you can series connect both the valves and feed them through just 1 regulator.
Ciao
Gianluca
Regulated Dc QuestionHide this!Advertise here!
Question about regulated PSU by CarlosFM. blackboy Chip Amps 28 6th July 2007 09:57 AM
reversing polarity in regulated B+ and other question jarthel Tubes / Valves 6 20th June 2007 01:19 AM
Regulated or non-regulated SMPS longitude Class D 5 8th May 2007 03:02 PM
Zen Variations Part 3: regulated supply question Decker Pass Labs 6 4th January 2006 12:25 AM
question about regulated supplies. martyh Chip Amps 0 11th January 2005 01:52 PM
