diyAudio Sponsor
Old 9th June 2005, 01:00 PM   #1
Default Affordable KT88
Hello again.
I'm considering building Mr. Mikael Abdellah's KT88 amp.
As always €€ are the problem.
Are there any cheaper equivalents for the KT88 tube (like a 6B4G to a 2A3, PCC88 to a ECC88...you get the picture) or a more affordable manufacturer?
I've seen some chinese KT88 for around €35 each, but from what i've searched here, they are not an option.
Mr Abdellah, if you happen to read this post, could you please share the PS schematic?
Thank you very much.
Old 9th June 2005, 02:05 PM   #2
Account Disabled
If euros are the problem why don't you go to cheaper tubes?
Say 6L6 or EL34.They're at 10-15euros each.
Try electroharmonix or J/J which are very good tubes.
Old 9th June 2005, 02:16 PM   #3
Sherman is offline Sherman  United States
I built Mikael's amp and used Valve Art KT88 tubes. They were about $22US as I recall. Not as cheap as EL34s but not too bad. Plus the amps (I built monoblocks) ended up sounding great.
I also used James 6123HS OPTs which here in the US cost me the same as Hammond 1628SE ($90US each).
--Sherman
Old 9th June 2005, 02:30 PM   #4
Look at www.jacmusic.com
KT 88 chinese costs around 20 € ea.
Old 9th June 2005, 03:53 PM   #5
I can get you GEC TT22 equiv or a pair GEC KT88 . See http://www.tubeworld.com/tt21.htm used but garanteed good condition .
TugaT
Old 9th June 2005, 04:10 PM   #6
Tuga, podia-me informar dos preços dum par (não é necessário serem matched, como já deve ter notado )
Sherman, thank you for the information about the tubes(what's your PS), as well as to Marcello1 for the link... nice prices!
I'm considering a national manufacturer of output trannies, they seem to be of very high quality, and at around 90 euro each with covers etc, etc. I will give them a try, as they were so helpfull determining the necessary tranny for this circuit and offered help on the PS. It will hurt on the wallet, but i'm not going down on this.
Old 9th June 2005, 05:43 PM   #7
Simpleton , it is a difficult item to find . TT22 € 60 each , KT88
€ 50 .
A national manufacturer ? You must be aware that the making of a good sounding output is not reachable by everyone . You must listen first , dig for others results . Remember it is the most important part .
TT
Old 9th June 2005, 05:51 PM   #8
www.edonion.com
[[ ]]'s
Old 9th June 2005, 07:59 PM   #9
I must confess it looks promising . Toroids carefully wounded as
in http://www.amplimo.nl . Thanks for the link .
So you think i asked too much for the valves ?
TT
Old 9th June 2005, 08:43 PM   #10
Sherman, thank you for the information about the tubes(what's your PS), ...
Here is my PS schematic. Really dead simple. The caps are ASC motor run (not start ) caps. Cheap and very effective. My PTX is a Hammond 273BX (remember I made monoblocks so each PTX only has to power one channel). The choke is a Hammond 8 Henry.
My mains voltage is a little high so my B+ is closer to 425 than 400 but still well within 10%.
--Sherman
affordable$$audio... Nanook Everything Else 6 4th May 2012 07:18 PM
Affordable transport? Shike Digital Source 3 29th August 2008 02:10 AM
affordable transformers for KT-88's namatjira Tubes / Valves 6 18th March 2008 11:35 AM
Affordable electrolytics bremen nacht Parts 8 2nd July 2004 11:12 AM
Affordable subwoofer jtriggs Subwoofers 19 4th February 2003 06:37 PM
Page generated in 0.28708 seconds (36.50% PHP - 63.50% MySQL) with 11 queries
