5902 amp schematics?
Old 3rd June 2005, 04:14 PM   #1
pokey17247 is offline pokey17247  United States
Default 5902 amp schematics?
Hello. I'm interested in building an amp using two 5902 sub-mini tubes.
I'm having some trouble finding schematics of amps using these tubes. I would like to run them push-pull, cathode bias.
Any and all info is welcome.
Thanks,
Anthony
Old 5th June 2005, 11:39 AM   #2
RE 604 is offline RE 604  Germany
RE 604's Avatar
Hello Anthony ,
look here :
http://www.jogis-roehrenbude.de/Lese...rmann-Mini.htm
It is single - ended , but maybe a help .
Regards , Alexander .
No reason to get excited : Jimi Hendrix .
Old 5th June 2005, 08:41 PM   #3
RE 604's Avatar
Here is the second link :
http://www.roehrentechnik.de/html/kolibri.html
Old 7th June 2005, 06:55 AM   #4
mwiebe is offline mwiebe  United States
Alexander, thanks for posting those links.
I have been using a 955 (acorn) driving a P-P 5902 triode connected to drive a Klipsch La Scala for a few years. However both driver and power tubes are battery biased, 1.2V and 6V respectively. I use the small Hammond 125C as outputs. I don't have a schematic to share but my B+ is 110V. Nice sounding amp and I've been meaning to play around a bit more with it--also try a pentoded 5902 as a driver. So by all means dive into your project.
Matt
Old 9th November 2011, 09:16 PM   #5
arensattic is offline arensattic  Netherlands
arensattic's Avatar
Default 5902 push-pull amp from Italy
Folks,
If I may add a link on 5902 amplifiers: there is a push-pull amplifier project posted on the "Radio di Sophie" site, run by Italian hobbyists. I have built a prototype (single channel) of Nicola del Ciotto's amplifier and it sounds good, but needs a preamp capable of providing 10V RMS output (or more).
The following document provides all information including PCB layout:
http://www.leradiodisophie.it/Downlo...to-Amp5902.pdf
(If anyone wonders: Sophie is (or was) an Abessynian cat with impressive looks, that liked to sit on working valve radios !)
Best regards,
Aren van Waarde (aka arensattic)
Real HiFi runs hot and has only one speaker unit per audio channel.
5902 amp schematics?Hide this!Advertise here!
schematics help just4copy Tubes / Valves 1 6th August 2009 11:44 AM
Schematics for SFD 2 dac JC951t Digital Source 2 9th April 2008 12:36 PM
BOSE Schematics DENSO Schematics packer Car Audio 6 25th June 2007 10:55 AM
5902 subminiature audio pentode Glass_painter Tubes / Valves 9 28th November 2004 07:27 PM
SUV-78 schematics please? demons_wing Solid State 2 26th April 2004 04:11 AM
