| diyAudio Sponsor | ||
Hi fellas!
I'm having a little problem with my pre-amp (seen on the photos thread): it lacks bass. the input cap is a 22nF and the output one is 68nF(or is it 680? it appears marked .68...) Could i ommit them or if not, what value should they be? Thank you very much, Francisco |
#2 |
The input as it is in the diagram has a -3db point at 20hz, this is too high in my opinion, tripple size of the cap and and the -3db point will be at 5hz.
The output cap depends on the amplifiers input impeadance, lets say bad case senario of a 10k input power amp, the the output cap will have a -3db point at 234hz really bad. If you do'nt have a power amp hooked up the output cap sees the 330k resistor only then the -3db point will be 7hz which is good but as soon as you hook up a power amp the 330k changes to what ever the the parralel of the 330k and the power amps input impeadace is and the bad case that i calculated was the 10k this is not acceptable. So the cap for 10k will have to be 4.7uf which will be good for nearly 100% of the poweramps out there. Cheers George |
#3 |
Thank you George.
Could you explain, if not too much trouble, the maths behind the calculations? |
#4 |
The output cap forms a voltage divider with the load. If the load impedance is R and the coupling cap is C, the response will be down 3 dB at f = 1/(6.28*R*C).
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#5 |
Simpleton the maths for the -3db piont are
2Pi x the resistance x by the capacitance 1/x = the -3db piont Cheers George |
#6 |
Another point often neglected is that the output impedance rises dramatically with small caps. In georgehifi's example it's literally 10 kohm at 234 Hz. Un- or poorly shielded interconnects need not apply. I found very small caps resulted in increased susceptibility to RF interference even when used as input caps in a shielded chassis.
#7 |
Another overlooked point-
The stage is using grid leak bias. When the bias is very low the input grid of the tube does not look like the ideal open circuit anymore. The input impedance of the grid is low enough that the lf performance of the input side of the tube is worse than the calculations would have you think. Gary |
#8 |
So...what should i do then?
Thank you all very much |
#9 |
Use a 4.7uF cap for your input. Even with the grid leak bias (nice catch, Gary, I missed that one!), your f3 will be low enough. And then you can start worrying about the next problem you'll have with this circuit, the high output impedance.
#10 | |
Just put a 4.7uf Solen on the input And a 15uf Solen on the output. You'll be right. Cheers George |
| Capacitor coupling question... | rtate | Solid State | 9 | 2nd August 2009 08:28 PM |
| Direct Coupling question | angsuman | Tubes / Valves | 2 | 27th July 2008 12:33 AM |
| Direct-Coupling Question | sorenj07 | Tubes / Valves | 10 | 25th April 2008 06:43 AM |
| Coupling cap.question.. | Dxvideo | Chip Amps | 20 | 1st December 2006 02:34 PM |
| Direct coupling question... | SHiFTY | Tubes / Valves | 8 | 3rd October 2003 09:49 PM |
| Page generated in 0.19347 seconds (49.28% PHP - 50.72% MySQL) with 11 queries |
