diyAudio Sponsor
Old 30th May 2005, 12:31 AM   #1
karma is offline karma  Canada
karma's Avatar
Default ebay toys
sweet another amp to rebuild
Old 30th May 2005, 12:33 AM   #2
karma's Avatar
needs alot of work and a new cage lol look at the cord
Old 30th May 2005, 12:34 AM   #3
karma's Avatar
happy dance
later..
Old 30th May 2005, 02:30 AM   #4
anatech is offline anatech  Canada
anatech's Avatar
Hey karma,
Another Bogen about to come to life. Right on.
Old 30th May 2005, 04:02 AM   #5
karma's Avatar
lately all i have been geting off ebay is bogen. just looked over my tubs i have all in need to test it before i rebuild it. if the iron is good i will be surprized its the only thing that looks like it has seen some heat than rusted over
Old 31st May 2005, 09:36 PM   #6
anatech's Avatar
Hi karma,
Don't forget these were PA amps. Many ran 24 / 7 for years. The transformers run warm, but are usually okay.
I've heard worse music amps - some new design.
-Chris
Old 31st May 2005, 10:57 PM   #7
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
I hope you're treating this amplifier as a learning process because that's a tiny output transformer (big is better)...
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 1st June 2005, 12:32 AM   #8
karma's Avatar
ya i have yet to get it. but it is a little small by looking at the pic
we shall see. i have a box of parts from old bogens if i need em
if it cant be restored ill mod it out
Old 1st June 2005, 01:28 AM   #9
karma's Avatar
here is the bottom pic it looks all original iron that is
ill lookup the model is if its the same
Old 1st June 2005, 02:12 AM   #10
karma's Avatar
ill look up the model to see if its the same iron
My New Hi-Res Toys Salas Multi-Way 20 8th May 2012 11:19 PM
got some more class d toys Tekko Class D 5 28th November 2007 01:17 PM
My new toys pinkmouse Multi-Way 15 25th May 2003 09:31 PM
More new toys pinkmouse Parts 0 10th May 2003 08:20 PM
cheap toys karma Everything Else 8 30th April 2003 08:39 AM
Page generated in 0.13634 seconds (64.63% PHP - 35.37% MySQL) with 11 queries
