-50V negative supply - Page 2 - diyAudio
Old 30th May 2005, 07:12 PM   #11
kevinkr's Avatar
Hold on a moment, it's not quite as simple as it may seem. Yes it is true that the differential voltage across the regulator is the key issue when operating, but notice the electrolytic on the reference terminal and also on the output - there is a small but significant delay due to the presence of that electrolytic on the reference pin, and depending on how fast the raw supply comes up you may be surprised to see more than the rated differential voltage across the input and reference pins of the LM337 even if for just a few milliseconds. I would add a moderately high voltage pnp transistor in series with the input pin of the regulator and reference its base to the output of the regulator through a 9V zener, note that you need to provide the base current as well so a resistor is needed from the base to the raw supply. (Make sure that you provide enough current to take care of both the zener and the base current. Note that it is not a good idea to ever allow the voltage on any terminal of a LM337 to exceed 40V, particularly relative to any other terminal. I would use the LM337HV which has a 60V rating in this application for slightly more margin. Note that different brands and vintages of LM337 can have different voltage ratings. Many are rated for no more than 35V/40V.
Here is the link to the national part.
http://www.national.com/pf/LM/LM337.html
Kevin
Edited to correct a typo and added another thought..
Old 31st May 2005, 10:31 AM   #12
Thankyou kevinkr.
Well, maybe the Lm337 is not the better solution for that work. I'll try to change something...
What do you think about the use of an IRF9510? With a reference chain made using some zeners this mosfet should work quite well. Look at the datasheet
http://chdist35.distrelec.com/distre...E/Data%20E.pdf
The Vds is -100V and power dissipation at 25 is 43W. Maybe it can support the heat dissipation without an heatsink for the load that it should drive.
Or maybe an IRF9610 (20W, Id 1.8A, Vgs -200V).
Mark
Old 31st May 2005, 11:04 AM   #13
jan.didden's Avatar
Kevin
Kevin,
You are right of course about the max voltage at start-up, but this can be avoided by putting a zener of, say, 33V across the LM337 so that the output cap can charge through this zener at start up. When the circuit is stable, the zener becomes invisible. Similarly with the cap at the ref point.
The alternative mentioned, a FET and a ref string, is a totally different circuit, it's not a regulator but just a stabilizer. It may be enough, but you cannot really compare the two.
Jan Didden
Music is dither to the brain; lets me think below the usual chaos - me
Linear Audio Vol 13 is out! Check out my Autoranger and SilentSwitcher
Old 31st May 2005, 11:39 AM   #14
Thankyou Jan. Yes of course a FET plus a ref string is just a stabilizer, but I think that it should work well because, in case of minimum difference in main voltage , the ccs should adjust its working point by itself.
However your advice to use a zener limiter sounds good!
Please look at schematic, post six. Should I change the 1n4002 with a 33V zener? That's all? I'll use a crc in front of the lm337, not only the single can shown in the schematic.
Mark
Old 31st May 2005, 01:39 PM   #15
jan.didden's Avatar
Mark
Yes, replace D2 with a 33V zener, same polarity. Use a zener of 1 or 2 watts, although with a CRC the 337 input voltage will not rise that fast, and with the small cap at the output (22uF) the one-time charge current will be modest.
Jan Didden
Old 31st May 2005, 09:40 PM   #16
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
I'll second the Zener proposal. I use a 22V Zener to protect the 317 in my general purpose adjustable constant current sink.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 31st May 2005, 11:33 PM   #17
Gary P's Avatar
Hi Mark,
Some good ideas for setting up and protecting the negative regualtor here.
My input is why regulate at all? The negative regulator is adding complexity with very little if any performance gain.
With the high performance CCS all you would need is a nice simple CRC filter that puts out more than -40 volts and less than -500 volts and your set. At the low current you specified (4ma) the CCS mosfet would not need a heatsink even if you ran the CCS at it's voltage limit of -500 volts...
Gary
Old 2nd June 2005, 11:20 AM   #18
OK Gary, thankyou for the advice. I liked idea to use a negative regulator, simply to have a stable ref voltage even if I should change the driver stage and the idle current. But if you say that with something between -40V and -500V the ccs works happy I'll try to use a simple CRC filter. Maybe I'll use a power transformer with a secondary that can provide at least 60Vac/1A, for this purpose.
Mark
Negative LTP CCS supply Klimon Tubes / Valves 14 18th March 2009 12:06 PM
I need a negative supply rail--but how? wally.gribbles Tubes / Valves 5 18th February 2008 07:36 PM
using a choke on a negative supply jarthel Power Supplies 3 22nd July 2007 09:46 AM
lm386 amp without negative power supply triden Chip Amps 3 29th January 2006 11:02 AM
Transistor current souce, negative supply Zodiac Power Supplies 2 31st December 2005 04:47 PM
Copyright 1999-2017 diyAudio
