Old 26th May 2005, 04:06 PM   #1
9900778 is offline 9900778  Hong Kong
Default 46 tube user
anybody has use #46 tubes??
is it better sound performance than 45 tubes??
It is worth to try??
wah
Old 26th May 2005, 04:48 PM   #2
SY's Avatar
I don't think they're interchangeable.
If there's a sucker born every minute, where do the rest of them come from?
Old 26th May 2005, 04:53 PM   #3
Giaime is offline Giaime  Italy
Giaime's Avatar
Send a message via MSN to Giaime
Instead I find on the ned many cheap 47s, is there someone that has used them? Maybe for a SE?
Old 27th May 2005, 01:47 AM   #4
amperex is offline amperex  United States
The 46 are regarded as a great driver tube. With the G2 connected to the plate, they operate Class A. I suspect the 46 would sound good as an output tube. I also guess the 45 might sound a little better, but at $50+ each for NOS, I would try that 46 tube.
Old 27th May 2005, 04:54 AM   #5
audiousername's Avatar
The '46 while triode strapped has been used by a few people as an output valve by some people - doing a Google search turns up some schematics.
Triode strapped, at 250Va and 22mA, into 6400 ohms, it will give around 1.25W. Not quite the same as a '45, but somewhat similar.
Jason
Old 27th May 2005, 08:06 AM   #6
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Gary Pimm has made a PP with the 47
http://home.pacifier.com/~gpimm/47.htm
Where? Where?
Old 27th May 2005, 09:56 AM   #7
frugal-phile(tm)
planet10's Avatar
wasn't there also a simple 47 SE in a recent audioXpress -- i went thru my tube collection and came up with a single example.... now if i could figure a use for all the 28 (or were they 26s -- time for bed ) i have.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 28th May 2005, 03:42 AM   #8
gerryc is offline gerryc  United States
Default Re: 46 tube user
Yes, absolutely worth a try. A couple of years ago I threw together a single channel (triode strapped) 46-based SE amp. Used a 6SL7 as a driver. I experimented with both classic grounded cathode and SRPP for the 6SL7 driver. Sounded a little different but I can't say definitely what I preferred. I also just used whatever junk PP output transformer was on the chassis I had (from Eric Barbour's idea for Single-Ended Glory for Under $100 GA 1997 Vol7 Num3). Ran the 46 at about 250 volts and 25ma.
I never built a "nice" version with two channels since I wanted to pursue a higher power design. But it definitely sounded nice even with one of my speakers which are something less than 90dB efficient. But definitely only enough power for a small room.
gerry
Old 30th May 2005, 11:51 AM   #9
Datubie is online now Datubie  United States
Datubie's Avatar
Shhhhhh..... don't let the secret out!
User manual for GTA SE-40 Tube Amp ? wckong Tubes / Valves 4 19th March 2013 11:54 AM
Velleman K4040 tube amp user feedback sought gjo Tubes / Valves 9 23rd January 2010 09:52 AM
New user maxmix69 Introductions 5 23rd March 2009 12:04 PM
User Name Change Speedskater Forum Problems 6 24th February 2008 10:23 PM
New User dbart43 Introductions 1 26th August 2007 06:52 PM
Copyright ©1999-2013 diyAudio
