Current sourced heaters in a CF
Old 23rd May 2005, 09:20 PM   #1
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Default current sourrced heaters in a CF
Hello
Can I use a current source heater PSU (LM317 R=1.25/I type) for a cathode follower and still bias it with voltage so to keep the cathode no more than 100V DC positive in respect to the heater?
I want to use 0.3A current source for 12AU7.
Do you prefer the sound of a current sourced heater?
Old 23rd May 2005, 10:26 PM   #2
kmtang is offline kmtang  Canada
kmtang's Avatar
I don't think you need constant current source for 12AU7 - indirectly heated filament. You can simply use DC regulator instead.
Johnny
Old 24th May 2005, 08:11 AM   #3
Salas's Avatar
Default hmm
I have read many times that a CS heater sounds better. That is why I want to try it.
Why you think its not needed?
Old 24th May 2005, 08:20 AM   #4
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Default Re: hmm
That's what i've heard... i've not built anything with DC heaters yet so i can't talk from experience.
It is pretty easy to implement why not just try it.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 24th May 2005, 11:37 AM   #5
Salas's Avatar
Default got the parts already
I have got the parts already (he he) but I was mainly interested in floating CT with voltage to avoid exceeding over 100VDC difference between heater and cathode. So I asked if they do this and how on a current sourced heater. I will listen to it anyway and let you know p10.
PS did you see that?:
http://www.diyaudio.com/forums/showt...threadid=57210
you are right to be a proponent
Old 24th May 2005, 12:54 PM   #6
kmtang's Avatar
The constant current source for filament supply is mainly used for Direct Heated Tubes like the 300B and 2A3. The reason is that the filament forming part of the cathode circuit which would affect the sound.
However, the indirectly heated tubes like the 12AX7 having the filament separated from the cathode, I don't see what CCS could do anything at all.
If you want to float the filament voltage, I think you can connect the -ve side of the CCS supply to the B+'s divider.
Just my 2 cents.
Johnny
Old 24th May 2005, 04:59 PM   #7
On Hiatus
SY's Avatar
The advantages are a gentler startup (heaters have lower resistance when cold) and a somewhat better potential efficiency. There's a nice treatment of these issues in Morgan Jones's book. The main thing to avoid is CCS operation of parallel heaters.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 25th May 2005, 03:23 AM   #8
gingertube is offline gingertube  Australia
The Allen Wright "Tube Preamp CookBook" recommends exactly this method - example circuits of current sourced heater supplies at elevated DC voltage abound. A RECOMMENDED book for any serious DIY Audio Nutter.
Ian
Old 25th May 2005, 07:05 AM   #9
thoriated is offline thoriated  United States
I've used a slightly different approach - a voltage regulated heater circuit that is current limited only a little higher than the required heater rating for soft start up.
Old 25th May 2005, 08:29 AM   #10
Salas's Avatar
Thanks people!
Current sourced heaters in a CFHide this!Advertise here!
Tube current regulation for series heaters' supply. engels Tubes / Valves 4 5th August 2007 10:49 PM
Current Sourced Cathode Follower dr._sleep Tubes / Valves 8 27th February 2006 08:46 PM
Current sourced heaters Salas Tubes / Valves 3 26th January 2004 11:09 PM
current sourced cascoded BLS schematic SteveG Pass Labs 48 24th July 2002 07:16 PM
