| diyAudio Sponsor | ||
#61 |
How about a low impedance SE transformer followed by an autotransformer?
Be sure your foil hat has a good low impedance ground. |
#62 |
I never paid much attention in those classes where they talked about transformers when I was going to school, I'm an RF engineer. I went to engineering school after I became an engineer! That is why none of my home made transformer experiments worked very well.
I was all set to order a pair of the big Hammonds from Angela Instruments (on their web site for $222 each), and get down to building "the big one" the old fashioned way. I tried calling them every day last week, and they were closed. When I got through today, they said that they had none of these in stock, and weren't going to order any more. Well, back to the drawing board. I know that my mosfets were blowing up because of "shoot through". This was because of dead time issues, and the fact that my P channel fets that had far less gate capacitance than the N channel fets (H bridge). I was using parts that I had about 4 years ago, which were several years old at the time. This may work much better with some modern fets. I just haven't had time to play with it. The basic concept of the circuit that I used is on my web site in case any of you get the urge to make some smoke! http://www.tubelab.com/SSopt.htm
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
#63 |
Got me thinking about pairing up my GU48 with one of my 813s and my homewound toroid, maybe without very high volts. Watching with a great deal of interest these couple of threads and the results of the 2A3/6V6 combination.
Great stuff! Mike |
#64 |
Since this thread popped up again, I'll just put some references here to later threads on related subjects:
http://www.diyaudio.com/forums/show...107#post1446107 http://www.diyaudio.com/forums/show...781#post1597781
Ohms Law V = I R |
#65 | |
Hello,
those links do not seem to work. - Elias Quote:
#66 |
"those links do not seem to work."
Hmmm, copy edit didn't work for some reason. Here's another try: http://www.diyaudio.com/forums/showt...07#post1446107 http://www.diyaudio.com/forums/showt...81#post1597781
Ohms Law V = I R |
#67 |
Just adding another reference link to the later threads on anti-triode:
Spud, Schade, PP, Anti-triode ECL86 and: My version of the Simple EL84 or rise of the anti-triode.
Ohms Law V = I R Last edited by smoking-amp; 10th February 2011 at 03:28 PM. |
#68 |
Arrrgh, that last one should be:
Ohms Law V = I R |
| MOSFET current source as triode load | Craig405 | Tubes / Valves | 46 | 14th April 2010 12:06 PM |
| Complementary input stages with current mirrors | jgedde | Solid State | 17 | 2nd December 2008 03:16 AM |
| Drive Current for EL509 Enhanced Triode | wrenchone | Tubes / Valves | 55 | 14th February 2006 03:07 AM |
| Melos High Current Triode | reinhard | Tubes / Valves | 0 | 4th March 2003 01:12 PM |
| Page generated in 0.10013 seconds (79.93% PHP - 20.07% MySQL) with 11 queries |
