Old 8th May 2005, 12:38 AM   #1
amaturetuber's Avatar
Lightbulb 2 To 3 Prong Conversion
JUST LOOKING FOR SOME HELP ON TAKING OUT A TWO PRONGED PLUG AND REPLACING IT WITH A THREE. SHOULD I GROUND IT TO THE CHASIS OR SOMEWHERE ELSE?......
Old 8th May 2005, 12:41 AM   #2
Speakerholic
Cal Weldon's Avatar
Please don't keep your caps lock on. There's no need to yell here.
Cal
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 8th May 2005, 01:37 AM   #3
audiousername's Avatar
Why do you want to replace the plug with a three-pronged kind? If it was designed to be safe with a two prong plug and that plug was damaged, doesn't it make sense to simply replace it with what it had before?
Anyway, how is this "Tube" related... Doesn't it belong in the "Electronics" section?
Jason
Old 8th May 2005, 10:20 AM   #4
Giaime is offline Giaime  Italy
Giaime's Avatar
Send a message via MSN to Giaime
Probably you're talking about old tube equipment. Yes, it is safer to use 3-prong mains cord, and it is a must. Just connect the safety ground wire (the yellow/green one) near the mains wire entry point, with a good connection to the chassis.
And also, if you've got the "polarity" switch (like old guitar amps) just remove anything that conects to it (sometimes there's a cap to the mains wires to the chassis, it's called "death cap" because you know what happens when it gets leaky or short ), remove it please, with the 3 prong connections the mains wires shouldn't have any connection with the chassis at all).
Bye!
3 prong speaker Bob0513 Multi-Way 15 8th March 2008 01:34 AM
dB/W/M conversion - M vs 0.5 M ?? MadMutt Multi-Way 3 26th December 2007 12:51 PM
rca conversion oogared Tubes / Valves 3 3rd September 2005 05:48 PM
three prong receptacle with 50 volts on ground lopan Solid State 11 12th October 2004 12:31 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
