That's what I pointed to, AFTER the tubes come hot !
Yves.
The conversion takes up most of the power
Yves.
Sounds like you are over-voltaging the tubes during power up.. Note that some Mullard ECC83/12AX7 are quite prone to bright flashes at power up and note also that these are the only ones I have EVER seen with open filaments. I have ruined several over the years this way...
Kevin
Kevin
