what do I replace...?
Old 3rd May 2005, 01:58 AM   #1
9am53 is offline 9am53  Canada
Send a message via MSN to 9am53
Default what do I replace...?
hello boyshere is my latest question...I finally decided to try the baxandall circuit for tone. some old ampeg portaflexes use an almost identical circuit with some different r/c values, but I dont know which to change...should I replace resistors 10 and 11, and caps 5,6,8,9? thanks
Guitar is Good
Old 3rd May 2005, 01:59 AM   #2
here is the schem for my amp
Guitar is Good
Old 3rd May 2005, 08:46 PM   #3
those resistors and caps that I am inquiring are from my amp...
Guitar is Good
Old 3rd May 2005, 09:28 PM   #4
leadbelly is online now leadbelly  Canada
leadbelly's Avatar
What are you trying to do? What do you replace => to do what?
There are still unbridgeable divisions between cultures. How can two peoples ever come to understand each other when one of them is ignorant of TotÚ? Umberto Eco
Old 3rd May 2005, 09:32 PM   #5
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
Ah, I'm glad it's not just me I can't understand either....
Old 4th May 2005, 03:10 AM   #6
sorry guys, as I often tend to do I assume everyone knows what I am talking about so I dont explain myself enough. I intend to switch out the resistors and caps from my amp and put in the ones from the ampeg. I am converting my PA into a guitar amp, so the tone stack as is doesnt work, but I am not sure exactly how many of the resistors and caps to replace...will C5 and/or C10/R13 have to be replaced, or do they not have a bearing on the tone controls...thanks guys
Guitar is Good
Old 4th May 2005, 03:40 AM   #7
On Hiatus
SY's Avatar
For whatever reason, I can't see the second image or click on it. Do others see it?
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 4th May 2005, 04:13 AM   #8
karma is offline karma  Canada
karma's Avatar
nothing here
Old 4th May 2005, 10:17 AM   #9
On Hiatus
SY's Avatar
9am, you might want to report that second schematic.
Old 5th May 2005, 02:14 AM   #10
hello, after what seems like an eternity of trying to make this thing fit 800x600 pixels here it is. R10 is 47K to ground. I guess what I am asking in a nutshell is whether I need only replace the r/c values within the tone stack, or if I need to change more ie, ones leading to and/or from the tone stack. thanks agian guys
Guitar is Good
what do I replace...?Hide this!Advertise here!
replace DAC maxpou Digital Source 13 21st February 2008 05:51 PM
Replace transistors huy801 Solid State 3 8th February 2008 04:01 AM
replace 5y3 ardan77 Tubes / Valves 5 15th January 2006 03:41 AM
Replace of CDM 4/19 with CDM 4/31? bezobraznia Digital Source 4 14th November 2005 03:56 PM
