| diyAudio Sponsor | ||
I found two of these tubes some time ago. I cant find any information on it so I have no idea what it is good for. Does anyone know how to use this tube and what it does? Thanks Lawrence
<a href="http://www.danasoft.com"><img src="http://www.danasoft.com/sig/lawbadman.jpg" border="0"></a><div style="font-family:arial,sans-serif;font-size:11px;"><p>Sign by Danasoft - <a href="http://www.danasoft.com">For Backgrounds and Layouts</a></p></div> |
#2 |
Here is another angle, if it helps.
#3 |
If I read correct, the name is CEA95. My tube database doesn't known it...
Btw the plate structure looks strange... It might be a triode, but I think for special purposes. |
#4 |
Is it some kind of magic eye tube, with the big plate been the display screen.
Shoog |
#5 |
by the looks of the structure, I'd say it is a <i forget the name>
it is sensitive to light, sort of like a photo-diode, but in tube format.. there is no heater, and the plate has some sort of mildy radioactive substance on it (like cesium? i forget) for use of transmitting a signal via visible light, like the audio track on a old film. I think I've got a similar tube from tim.. |
#6 |
I'ts a photodiode
I worked at a factory that made silicon photodiodes vacuum multipliers and CRT's amongst other things like neutron detectors and Boron isotopes. I cant' help with specs but remember seeing one of these in the lab for calbration purpose. Pete |
#7 |
Used to use these in old cinema projectors!--Machines like Kalee with B.A.F Soundheads and Westar machines.
Biassed at around 90v, the film audio track was projected through a slit and optics to the selenium coated cathode which then emitted electrons depending on light intensity Used to go noisy, microphonic and all sorts, Just an ornament these days!
Das Beste Oder Nichts |
#8 |
Brian |
#9 |
Yup what Colt said, the word is phototube. The cathode is coated with cesium which has a lot "work potential", basically electrons are more prone to being bumped out by light rays. Add 300V and you get a few micro to miliamperes plate current depending on intensity. I think response drops off around 10-20kHz typically.
Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing. The key to being a successful Audiophile: "I reject your reality and substitute my own!" |
#10 |
Thanks a bunch Guys.
Now that I know what it is I really dont have any use for it. Anyone have any ideas? I may just end up selling them anyway, if they are worth anything. thanks Lawrence
| Hi there (kind of) | ifrythings | Introductions | 7 | 28th October 2005 10:43 PM |
| Different kind of sub | rjon17469 | Subwoofers | 7 | 16th November 2004 08:42 PM |
| Other Kind of DIY | Algar_emi | Everything Else | 11 | 28th April 2003 12:48 PM |
| What kind of amp is this? | swirv | Solid State | 5 | 1st February 2003 12:53 AM |
| Page generated in 0.09755 seconds (76.54% PHP - 23.46% MySQL) with 11 queries |
