| diyAudio Sponsor | ||
Hi all,
Seeking comments on this circuit design. Any takers? Column one here rest to follow. Sorry about format of post, but I can't remember how to get my image to link from the web. Michael |
#2 |
Hope it's readable. Again sorry for the format.
Michael |
#3 |
It's the split-load design that was popularised by McIntosh. I believe Audio Research are still keen on it. What the diagram doesn't show is that you need an awful lot of swing from the driver stage. A common way of solving that problem is to use the output anodes as bootstrapped HT supplies for the drivers stage. It works, but it makes stability very much harder to achieve.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
#4 |
More than that, the driver distortion rises in proportion to the positive feedback achieved by the bootstrap.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#5 |
Good point. As the HT voltage rises, the current through the anode load resistor rises, so it appears to the valve as a reduced value of anode load resistor, causing a steeper loadline and increased distortion. There's just no free lunch...
#6 |
While I am not able to argue your assertion in the electrical sense, this article is from the Proceedings of the IRE July 1954 while the McIntosh circuit was published as least as early as 1949. This would seem to make it unlikely they are the same. Though I have difficulty deciphering the schematics in the McIntosh paper I do not see the capacitive coupling of the cathode windings with the plate windings as shown in the scheme I posted. True? Are there other differences? Enlighten me.
Thanks, Michael |
#7 |
The capacitors allow the transformer to be made without bifilar winding as in the McIntosh design. The caps provide the close coupling between sections to overcome xfmr leakage reactance. The text refers to this and that it would be cheaper to build.
Don
Ohms Law V = I R |
#8 |
From the other side, as found in the McIntosh article. If bifilar winding does away with the need to sectionalize the primary where is the disadvantage? The need for thicker insulation?
Another question, is this output stage necessarily unity gain? Michael |
#9 |
Hi Michael,
It's exactly the McIntosh circuit except for the 'bridging' caps. Both McIntosh and Amemiya were interested in reducing crossover distortion in class B amps by AC coupling the cathode winding of one tube to the plate winding of the other. Mac did it by specifying bifilar windings and Amemiya used a cap and a presumably cheaper transformer. In any case, it's not clear what the tight coupling buys you in class A. In other words, a class A amp without bifilar windings might work equally well with and without Amemiya's cap. -- Dave Cigna |
#10 |
The insulation requirements of the Mac transformer windings are indeed nontrivial.
The output stage does not necessarily need to be unity gain. Caps are not the only way to couple the windings to make up for difficulties in the transformer- one could use MOSFET source followers.
| Design Help (load line) on a SE Mono Block Amp build | myDogFred | Tubes / Valves | 3 | 17th January 2009 08:44 AM |
| Distributed Load/Balanced Bridge Connection | NickC | Tubes / Valves | 1 | 1st October 2005 09:38 PM |
| [OT] Design a MOSFET heat Load | akira | Solid State | 2 | 17th March 2004 06:36 AM |
| [OT] Design a MOSFET heat load | akira | Pass Labs | 3 | 14th March 2004 09:08 PM |
| Page generated in 0.10822 seconds (78.66% PHP - 21.34% MySQL) with 11 queries |
