"lift off " or "Houston we have a problem"
Old 30th April 2005, 02:49 AM   #1
tenderland is offline tenderland  United States
tenderland's Avatar
Default "lift off " or "Houston we have a problem"
After countless hours and dollars, periodicals and posts , I am ready to power up my 2A3. Any words of wisdom before power up ?
Old 30th April 2005, 03:13 AM   #2
karma is offline karma  Canada
karma's Avatar
take cover
Old 30th April 2005, 08:04 AM   #3
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Usa a variac and check voltages as you ramp up the voltage...
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 30th April 2005, 10:07 PM   #4
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
Make sure the room is absolutely quiet and sniff the air constantly.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 1st May 2005, 01:42 AM   #5
frugal-phile(tm)
planet10's Avatar
for the totally disgusting, but too familar, smell of components with the smoke letting go?
dave
Old 1st May 2005, 02:48 AM   #6
adason is offline adason  United States
adason's Avatar
variac is the best, but if you dont have it, you can use incadescent bulbs
powering it trhough the bulb will tell you how much current it draws, if too much, bulb's too bright and eventualy burns depends on wattage
i suggest you test power suply separately first, lets say with three/four bulbs in series
good luck!
Old 1st May 2005, 03:50 AM   #7
Burnedfingers is offline Burnedfingers  United States
Dave is correct...
Bulbs can be used also but being able to monitor the amperage says it all.
I suggest 5 or 6 shots of the hard stuff tonight followed by firing it up tomorrow.
Old 1st May 2005, 04:42 AM   #8
tenderland's Avatar
Default Lift off
As suggested I used the variac. I monitored the b+ and just had the rectifier in all was good 320 volts. I put all the tubes in and brought it up slowley......... 20 volts . I checked each ch seperately
same same . I went in ... turned out had a bad connection from the B+ ground bus to chassis ground(star ground for the world). IT WORKS .......... . Thanks to every one who answered all my dum nub questions.
Jeff
Old 1st May 2005, 05:15 AM   #9
frugal-phile(tm)
planet10's Avatar
Default Re: Lift off
Yippy
what are you using it with? And how does it sound?
dave
Old 1st May 2005, 05:29 AM   #10
tenderland's Avatar
Default set up
Speakers -- Fostex 167 - base reflex
audioquest cables - slate
SONY - X555ES CD PLAYER
NAD - preamp (not realy needed )
How does it sound - Very clean , no hum , a little harsh , not much bass...
"lift off " or "Houston we have a problem"Hide this!Advertise here!
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 06:42 PM
FS: Seas Excel TL Home Towers "Thors" Houston/Austin pickup only kappa546 Swap Meet 15 1st September 2008 03:12 PM
"Houston we have a problem" Isobarik Sub Fearlessleader1 Subwoofers 18 14th December 2005 06:57 PM
Some final pics of "Stacks" revisited and "Askew" with stand Andy G Multi-Way 2 3rd February 2005 06:07 AM
Anyone used Scan-Speak's "Flow Resistors" or "Aperiodic Vents"? Ignite Multi-Way 3 18th November 2001 08:42 AM
Copyright ©1999-2017 diyAudio
