Help with homebrew mic preamp please!!! - diyAudio
Old 30th August 2002, 02:58 PM   #1
Default Help with homebrew mic preamp please!!!
Hi everyone,
I have been messing around with a balanced preamp for a low impedance dynamic microphone (like a shure sm-57). Problem is I don't know much about this stuff and have no software to help build it. So, I have been tweaking wires and values to get good results, mainly using potentiometers in place of the cathode and plate resistors. I have attached my circuit and was wondering if I could get some comments on it, or maybe even have someone build it in software and test it!! That would be most appreciated.
I know that mic preamps really benefit from a transformer or solid state input for hi gain and low noise, but I just want to try something different here. C
ould anyone suggest a good output stage for this thing?
Is it un-common to have a balanced, low signal pentode input stage?
What exatly do you do with the screens grids in this situation?
Thanks for any help at all. The circuit is attached below...
-Matt Mitchell
Old 30th August 2002, 06:27 PM   #2
Have a look at this, it may help or give you some ideas.
http://laplaza.taos.nm.us/~fvuotto/micpre.html
Old 31st August 2002, 12:25 AM   #3
dice45 is offline dice45  Germany
Matt,
dynamic microphones are like moving coil cartridges in output level and source impedance.
Methinks, pentodes are too noisy for that.
A circuit you could try : look at Allen Wright's differntial preamp RTP3 or RTP5. His website is www.vacuumstate.com . TMK, this preamp also was used as professional µphone preamp. Without phono EQ of course.
The thing uses cascodes for the input stage, the lower system being a 2SK147 FET and the upper one an ECC88 triode section. This preamp has no noise problems and is ultra-neutral; detail resolution is top-notch.
Bernhard
Old 31st August 2002, 10:25 PM   #4
DrExotica's Avatar
Default ISO MC pre-amp design
On the topic of moving coil cartridges, is anyone aware of a reasonable pre-amp design that can handle one? Most of the designs that I have seen are for moving magnet. I have a Linn Troika on an LP12 that I'd love to be able to send through a tube pre-amp and amp.
Thanks for any ideas.
Erik
Old 7th September 2002, 03:19 AM   #5
diyAudio Senior Member
fdegrove's Avatar
Erik,
Take a look at the thread Marjan posted for 6922 in the directory of this section.
Several circuits were suggested there.
Rgds,
Frank.
Frank
Old 14th September 2002, 10:54 AM   #6
fdegrove's Avatar
Default MIC PREAMP
Hi Matt,
Check out this link for inspiration on yr. project:
http://www.gyraf.dk/gyraf2/gy_pd/g7/gic.htm
Rgds,
Frank
Old 15th September 2002, 06:48 AM   #7
Brett's Avatar
Default Re: ISO MC pre-amp design
Erik,
If you want a single ended design, look at www.vacuumstate.com for the FVP5.
Cheers
Brett
Homebrew Car Audio DVD player Bob Wells Car Audio 8 10th November 2011 01:00 PM
FS: Homebrew 6V6 PP tube Amp $60.00 Sal Brisindi Swap Meet 2 11th July 2007 01:09 PM
Homebrew Spectrum Analyzer Duo Everything Else 44 14th March 2007 08:44 PM
Is it possible to homebrew better than the big guys? walker Solid State 63 12th January 2004 12:47 PM
Homebrew poweramp... koolscooby Solid State 13 27th December 2003 02:10 PM
Copyright ©1999-2017 diyAudio
