Vacuum tube modeling software - beta testers wanted - Page 3 - diyAudio
Old 17th May 2005, 01:16 AM   #21
wa2ise is offline wa2ise  United States
wa2ise's Avatar
A lot of bloodshed here too....
child killed: illegal instruction
while executing
"exec $backend -$type -m << [$t get 0.0 end]"
(procedure "model" line 9)
invoked from within
"model $wd.text"
invoked from within
".n.f1.buttons.model invoke"
("uplevel" body line 1)
invoked from within
"uplevel #0[list $w invoke]"
(procedure "tk::ButtonUp" line 24)
invoked from within
"tk::ButtonUp .n.f1.buttons.model"
(command bound to event)
error I got when using 6SN7.dat to build a model.
PC is a Pentium III running Windows 2000 Pro.
Old 17th May 2005, 05:27 AM   #22
argo is offline argo  Estonia
Ditto
PC: P4, Win XP
Old 17th May 2005, 10:05 AM   #23
LuisMCP is offline LuisMCP  Spain
Audio fanatic
LuisMCP's Avatar
Default new version of Curvecaptor for WinXP
Hola a todos,
Andrei is travelling now and he can't login to Diyaudio Forum, so he asked me if I would tell you a link to a new version of Curvecaptor suitable for testing under Win_XP plattforms.
Lasts results are Ok when running under these conditions:
- Win XP Professional - SP2
- AMD Athlon XP 2000+ Processor
Download Curvecaptor from:
http://sourceforge.net/projects/curvecaptor/
Saludos,
Luis Cardaba.
Old 18th May 2005, 04:55 AM   #24
wa2ise's Avatar
Talking it works now!
The latest version works well. My machine is a Pentium III running Windows 2000 Pro. Below are a few models I did with the new version today (a few low B+ voltage tubes for people who haven't gotten used to high voltage just yet):
These I did using AF's software
* 12u7 Spice 3F4 model low voltage space charge dual triode
.SUBCKT X12u7 P G K
Bp P K I=(0.001972003403e-3)*uramp(V(P,K)*ln(1.0+(0.001530503245)+exp((0.038 59673121)+(0.03859673121)*((564.8225939)+(-114911.4871e-3)*V(G,K))*V(G,K)/sqrt((15.44447752)^2+(V(P,K)-(8.343447975))^2)))/(0.03859673121))^(1.148627719)
CPK P K 0.0000000000004
CGK G K 0.0000000000016
CGP G P 0.0000000000015
.ends X12u7
* below is a 12AX7 style triode running on 80% of its normal heater voltage, improves linearity. The 12AV6, ignoring its diodes, is half a 12AX7.
* 12av6-10vh Spice 3F4 model
.SUBCKT X12av6-10vh P G K
Bp P K I=(0.008002535364e-3)*uramp(V(P,K)*ln(1.0+(0.1781769699)+exp((4.80847 8051)+(4.808478051)*((80.28638516)+(-6220.101955e-3)*V(G,K))*V(G,K)/sqrt((71.2061203)^2+(V(P,K)-(51.18537952))^2)))/(4.808478051))^(1.174758456)
Cgk G K 2.2P
Cgp G P 2P
Cpk P K 0.8P
.ends X12av6-10vh
*Below is a detector diode running on 2/3 normal heater voltage, improves detector performance.
* 5896 4v on 6.3 heater not valid over 30ma; with contact potential
.SUBCKT X5896-4hv P K
Bp P K I=(1.259102866e-3)*uramp(V(P,K)+(0.6788214279))^1.5
.ends X5896-4hv
* 12FM6 Space charge low voltage triode
.SUBCKT X12FM6 P G K
Bp P K I=(0.001097962853e-3)*uramp(V(P,K)*ln(1.0+(0.06123349699)+exp((0.0216 1200134)+(0.02161200134)*((23.7503614)+(-156710.2813e-3)*V(G,K))*V(G,K)/sqrt((-6.356755714)^2+(V(P,K)-(6.569413423))^2)))/(0.02161200134))^(1.51472413)
CGP G P 0.0000000000017
.ends X12FM6
My Circuitmaker 3F4 spice simulator turns out to be okay with "exp" but barfs
on "m" and "k" at the end of numbers. I sub "e-3" and "e3"
respectively and it works. Also Circuitmaker barfs on N^X when X is less than 1. Doing 1.5453^0.6 makes it barf, but a work around
that does work is to do sqrt(1.5453^1.2). This reminds me of why
software writing aloways drove me nuts; stupid stuff like this!
Old 21st May 2005, 03:47 AM   #25
wa2ise's Avatar
More models I did using this software can be had here.
It's a txt file, cut and paste into your spice program.
Any chance of software like the above for pentodes? I realize the screen grid throws in more variables, so maybe not....
Old 25th May 2005, 09:01 AM   #26
andrei is offline andrei  Canada
Well, I'm back...
First of all, sorry for the mix-up with Windows binaries, Pentium 4-specific optimization was applied generating instruction set missing on other processors.
The next version (0.9.1) is in the works. It will remove limitations of Windows port (disabled distortion analysis) and add support for user Spice dialect selection (3F4, PSpice, and LTSpice so far). If you want your favourite Spice included, email me with the description of the syntax it uses.
Tetrode/pentode support is possible, but I have not seen many models around - only the simple ones. Might be a bit of try-and-fail work to get the model that is flexible enough to fit well. I am postponing this until after 1.0 release is out.
Old 25th May 2005, 05:23 PM   #27
Radames is offline Radames  United States
Default Pentode models
Hi Andrei,
I used the Koren pentode model with mixed results. The fitting is tricky and I couldn't get it to cenverge very well (I used Matlab fsolve).
Did you explored other models? If so, are they online somewhere, or published? I'd like to know if there is something.
Rada
Old 27th May 2005, 06:58 PM   #28
Luap is offline Luap  United States
Andrei,
Thanks so much for the software. I have been using Teodoro Marinucci's excel sheet to create models (appears to be gone now ), yours looks to have great potential. I look forward to your LTspice output code.
I really like how Teodoro breaks out the parameters/values from the equation as this makes it easy to tweak (trial and error) to get as close as possible in LTspice. -If your LTspice output can be done this way, it would be really helpful for me.
example:
*Attempt by Luap at a 12u7 using koren calq
.SUBCKT 12u7kor 1 2 3 ; P G C;
+ PARAMS: MU=21.95 EX=1.1 KG1=1082.66 KP=68.5 KVB=490.4 RGI=1000
+ CCG=2.3P CGP=2.2P CCP=.9P ; ADD .7PF TO ADJACENT PINS; .5 TO OTHERS.
E1 7 0 VALUE=
+{V(1,3)/KP*LOG(1+EXP(KP*(1/MU+V(2,3)/SQRT(KVB+V(1,3)*V(1,3)))))}
RE1 7 0 1G
G1 1 3 VALUE={(PWR(V(7),EX)+PWRS(V(7),EX))/KG1}
RCP 1 3 1G ; TO AVOID FLOATING NODES IN MU-FOLLOWER
C1 2 3 {CCG} ; CATHODE-GRID; WAS 1.6P
C2 2 1 {CGP} ; GRID-PLATE; WAS 1.5P
C3 1 3 {CCP} ; CATHODE-PLATE; WAS 0.5P
D3 5 3 DX ; FOR GRID CURRENT
R1 2 5 {RGI} ; FOR GRID CURRENT
.MODEL DX D(IS=1N RS=1 CJO=10PF TT=1N)
.ENDS
I would be glad to make some suggestions when you are ready (I assume it's a bit early) ...just let me know.
Luap
Old 27th May 2005, 06:58 PM   #29
...one more thing
-FYI
tried it with both XP and 98SE on a PIII
similar results
Luap
Old 27th May 2005, 07:10 PM   #30
Audio fanatic
LuisMCP's Avatar
Originally posted by Luap
Andrei,
Luap
Hi Luap,
Have you Teodoro Marinucci Excel sheet?
I would like to download it, because Marinucci's web is shut down.
Regards.
wanted: Coral Beta 8 or Beta 10 full range speaker francofil Swap Meet 2 28th April 2010 08:34 AM
Vacuum Tube Computer Simulation Modeling oldheathkitphil Software Tools 11 19th July 2007 02:12 PM
HELP with Box Modeling Software 69stingray Multi-Way 5 1st January 2006 04:40 PM
Need help with Modeling Software Wright Multi-Way 26 17th November 2003 01:23 PM
Copyright ©1999-2017 diyAudio
