diyAudio Sponsor
Old 29th April 2005, 03:29 AM   #1
cominup is offline cominup  Viet Nam
Send a message via Yahoo to cominup
Default 6V6 in triode connect mode
Dear all,
Pls, see attachment, RCA manual 6V6GTA. They said that in triode connection mode, at 250V plate voltage, plate resistance is 1960ohms.
Have you ever tryed this one before? Or could you suggest schematic to operate this mode. How about SRPP 12AT7 for driver?
Thanks in advance
Cominup
Ill do it by myself
Old 29th April 2005, 08:39 AM   #2
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Sure. Mind that you'll get one watt if you're lucky. 6V6 is a skookum pentode but at best a weak triode only suitable for heavy driver applications.
Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing.
The key to being a successful Audiophile: "I reject your reality and substitute my own!"
Old 29th April 2005, 12:36 PM   #3
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
"Skookum" pentode? Qu'est que c'est?
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 29th April 2005, 12:44 PM   #4
audiousername's Avatar
Err... sort of "good"
http://en.wikipedia.org/wiki/Skookum
Jason
Old 29th April 2005, 12:50 PM   #5
EC8010's Avatar
Thank you for that. No wonder I hadn't heard the word before...
Old 29th April 2005, 05:57 PM   #6
frugal-phile(tm)
planet10's Avatar
Thanx for that... the word has been in my vocabulary for ever... now i know where it came from.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 29th April 2005, 06:03 PM   #7
leadbelly's Avatar
Default Re: 6V6 in triode connect mode
http://audiotropic.netfirms.com/blurb1.html
Aerodynamics are for people who can't build engines. Enzo Ferrari
Old 1st May 2005, 01:55 AM   #8
PRR is offline PRR  United States
PRR's Avatar
Any pentode can be a triode. But in a pentode, the screen grid sucks big current even when plate voltage is low. So a pentode is designed for a high Mu (G1 to G2), 10 or 20, for good power sensitivity. In a triode, current falls when plate voltage falls. You want a low Mu, like 5, to reduce this effect. 6V6 Mu is 10. So it is OK but hardly great as a triode power amp.
For 1935, this was very good performance. It might still be pretty good for 6V 0.45A heater power. It won't knock your socks off.
I've used the 10 Watt plate rating, which really applies to TV V-sweep duty. SET duty is tough too, but perhaps less likely to gross abuse than cheap TV work, so at your discretion you could run 12, 14, even 18W in your 6V6 (they are tougher than the book says).
Two possible operating conditions:
B+ = 350V
Iq = 28mA
Vpk = 210V
Ipk = 28mA
load = 7.5K
power = 2.8 Watts
grid = 0V/-30V/-100V
THD = gross
maybe 1.4W with listenable THD at 320V, 30mA, -25V bias
B+ = 240V
Iq = 40mA
90V pk
22mA pk
load = 4.1K
power = 0.9 Watts
grid 0V/-14V/-33V
THD ~ 10%
Ah: RCA's 1940s datasheet gives suggested values for triode operation, somewhat better than my estimates because they push the 14W rating for audio triode operation.
Huh? It only needs 15V-20V of drive, with 250V-300V of supply voltage available. No reason to muck it up with complicated drivers. For zero-feedback operation, a 6SN7/12AU7 is plenty of gain. If you want damping better than 2, use 6SL7/12AT7 and take some NFB around everything.
Old 2nd May 2005, 03:12 AM   #9
TJ is offline TJ
I hv seen a lot of 6v6 schmatic connect in Push pull mode but very few in UL , why ? bad sound or what ? please let me know . cheers
Old 2nd May 2005, 04:40 AM   #10
frugal-phile(tm)
planet10's Avatar
Originally posted by TJ I hv seen a lot of 6v6 schmatic connect in Push pull mode but very few in UL , why ? bad sound or what ? please let me know . cheers
6V6 was never designed with the intent of UL operation like the EL84 or EL34 were.
dave
Boosted Triode mode? Jeb-D. Tubes / Valves 2 21st August 2007 02:28 AM
how to connect an EL34 pentode into a triode and 100ohm resistor between plate and g2 jarthel Tubes / Valves 8 18th November 2006 11:37 PM
Using a spdt switch to select between triode mode and pentode mode on a guitar amp. G Tubes / Valves 19 15th March 2006 09:15 AM
47 Penthode in triode mode. Diy martin Tubes / Valves 6 24th September 2005 01:16 AM
Mullard 5-20 in triode mode icebear Tubes / Valves 15 26th November 2004 02:06 AM
Page generated in 0.11273 seconds (83.07% PHP - 16.93% MySQL) with 11 queries
