| diyAudio Sponsor | ||
#11 |
No reason why you can't use UL for 6V6 - Va max 315V and Vg2 max 285V - I'd say its damn near ideal.
There is a fellow here in OZ whose been designing and building his own tube amps for 30+ years. He claims his favourite amp is 8 off 6V6 UL connected per channel (4 pairs). On my estimates he probably gets about 40 Watts. I'm a big UL fan - check out IM distortion figures for Triode, UL, Pentode of just about any output pentode data sheet and guess which is best - UL everytime. This is telling me that UL is the most linear mode to run a Pentode. Also easier to drive than Triode Mode (low input capacitance). Cheers, Ian |
#12 | |
#13 | |
frugal-phile(tm)
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
| Boosted Triode mode? | Jeb-D. | Tubes / Valves | 2 | 21st August 2007 02:28 AM |
| how to connect an EL34 pentode into a triode and 100ohm resistor between plate and g2 | jarthel | Tubes / Valves | 8 | 18th November 2006 11:37 PM |
| Using a spdt switch to select between triode mode and pentode mode on a guitar amp. | G | Tubes / Valves | 19 | 15th March 2006 09:15 AM |
| 47 Penthode in triode mode. | Diy martin | Tubes / Valves | 6 | 24th September 2005 01:16 AM |
| Mullard 5-20 in triode mode | icebear | Tubes / Valves | 15 | 26th November 2004 02:06 AM |
| Page generated in 0.07486 seconds (68.17% PHP - 31.83% MySQL) with 11 queries |
