Bad tube? - Page 2 - diyAudio
Old 6th May 2005, 10:31 PM   #11
jogas is offline jogas  Italy
Hi n0plb,
I got the schematic from the Svetlana site and I just turned the tube operated PSU into a solid state one.
I also used DC biasing for the heaters.
Attached you will find the schematic.
I have not done any picture of the bottom side
Old 8th May 2005, 08:14 AM   #12
LuisMCP is offline LuisMCP  Spain
Audio fanatic
LuisMCP's Avatar
Default Re: Bad tube?
Originally posted by jogas
I am testing a new PP 300B and I have one tube showing an intermittent blue light as shown in the attached picture.
Does this mean it is a bad tube or any gas/vacuum leakage?
Thanks for your help
Hi Jogas,
Intermitent blue glow is bad for me. Sometimes is for oscillating circuit, and one time it was for failure tube (320B-XLS) that inject an horrendous noise when blue glow appears.
Permanent blue glow is normal.
Do you have large and intermitent noise?
Cheers.
Luis.
Old 8th May 2005, 12:50 PM   #13
richwalters's Avatar
Default Re: Re: Bad tube?
Cheers.
Luis.
Hi there.........I had this intermit blue glow problem with a batch of EI KT90's.....only to find when <I tapped the envelope it disappeared.......internals mechanically unsound....intermittent int contact somewhere. The blue glow disappeared simply because the tube s/c and blew B+ fuse....
richj
Old 8th May 2005, 06:32 PM   #14
no, I haven't any noise, nor continuous neither intrmittent,
it just looks like a nice blu light...
need diy tube preamp (line-stage) recommendation and general tube advice Musiclover4 Tubes / Valves 16 18th May 2013 03:19 PM
FS tube tuner, Active filter kit, tube amp, amp3 Josephjcole Swap Meet 9 20th July 2007 04:05 PM
SS or tube voltage amplifying stages in an amp with tube output? ray_moth Tubes / Valves 14 4th July 2007 03:09 AM
tube driving the same tube - whats the collective word? zobsky Tubes / Valves 3 13th June 2005 06:47 AM
Copyright 1999-2017 diyAudio
