DIY Powdered Iron Tranny Core
Old 26th November 2005, 11:33 AM   #71
Tweeker is offline Tweeker  United States
How would powered iron from a cylinder head porter compare? Much less common, but still available.
Be sure your foil hat has a good low impedance ground.
Old 1st December 2005, 04:27 AM   #72
Frenchman is offline Frenchman  United States
Valveitude,
This is amazing. Continue the excellent work. This is beyond DIY into the realm of the garage/backyard/attic experimentor. A great deal of our modern day knowledge has been gained through people such as yourself. Also take note that most have had a sizeable group of naysayers. This doesn't mean your idea will work, but it certainly shows that just because conventional wisdom says it isn't possible doesn't mean it's right.
I will continue to watch this thread and anticipate your results with great enthusiasm.
Old 1st December 2005, 12:44 PM   #73
valveitude is offline valveitude  United States
valveitude's Avatar
Well I see this thread has been brought back from the dead
I'm afraid I have given up for now. I still am not convinced I couldn't reach a mu in the low hundreds, but my best efforts before shelving it was no where near that.
It was filthy hard work getting as far as I did, and I decided my hobby time was supposed to have some joy in it. Currently I have been working on a Teres-like (with possible improvements )turntable. If interested you can see it here...
http://www.diyaudio.com/forums/showt...threadid=67089
Thankx to eveyone in this thread for participating.
Casey
Experience is a wonderful thing. It enables you to recognize a mistake when you make it again.
Old 19th December 2005, 05:27 AM   #74
Brian Donaldson is offline Brian Donaldson  United States
Brian Donaldson's Avatar
Hey, I want to make my own OPT's, and I am reinventing the wheel.
I want trifiliar primarys (for 3 parallel output tubes), a dc bias coil to offset the se bias, and multiple taps for output impeadance.
But what I seek is a source of EI laminates without resorting to buying microwaves from Wallmart for disection.
I can put together a gearhead motor with a rev counter and a former and I can find the formulas to get me in the ballpark, If I can source the laminations.
Old 19th December 2005, 06:46 AM   #75
Sylvania is offline Sylvania
Default trifiliar primarys / EI laminates
Hi
The only EI laminates i could buy where from a Danish import company, and they would only deliver when buying between 800 - 1100kg of ion So my OPT is made of scrap.. Remember that you will need some space for trifilar primarys. Mine is bifilar primarys for SE parallel Tubes , and the cores is stuffed!
Best regards Kim Olesen
www.micro-io.dk
DIY Powdered Iron Tranny CoreHide this!Advertise here!
Which, Foil Air Core or Iron Core Inductors slhijb Multi-Way 16 20th November 2009 03:12 AM
Inductors with powdered iron toroids. GK Power Supplies 9 11th August 2008 08:42 PM
DIY Powdered Core Progress Report valveitude Tubes / Valves 15 5th May 2005 02:46 AM
Selecting audio tranny core size ashok Tubes / Valves 16 2nd April 2005 07:49 AM
Solen Air core inductors, Hammond Iron core. gnomus Swap Meet 0 30th July 2004 01:28 AM
