changing (de)coupling cap values - Page 2 - diyAudio
Old 25th April 2005, 07:58 AM   #11
Klimon is offline Klimon  Belgium
Sorry, in my previous post I used cathode instead of grid. The technical terms for these resistors seem to be: grid stopper resistor and grid leakresistor (which I don't know what to do with)...
Old 25th April 2005, 08:09 AM   #12
Yvesm is offline Yvesm  France
Yvesm's Avatar
Grid leak resistors are between grid and ground (or bias source).
They are intented to fix the DC grid voltage and MUST exist.
Sometimes, a volume control do the job.
In low level stage, they are something between 100k to 1M.
Grid stopper are in serie with grid.
They prevents for some kinds of parasitics oscillation and are only added when needed.
Theyre values are in the 500 to 10K range.
Much more left to say about !!
Yves.
Old 25th April 2005, 08:26 AM   #13
Merci, Yves!
I gather the grid leak resistors should simply be left as is then...
Old 25th April 2005, 08:49 AM   #14
Yvesm's Avatar
Merci, Yves!
Agreed
Old 25th April 2005, 09:33 AM   #15
Just removed the pio input caps, left the grid leakresistors as is. Audible results: all sing along: "the best capacitor is no capacitor"!!!
thanks for the replies, I'm done
help in changing cap values for a disto stompbox pinkanarchy Parts 3 22nd June 2008 03:26 PM
Calculating values for input coupling capacitor officeboy Chip Amps 14 29th January 2006 04:41 PM
Coupling cap. values??? stoo Tubes / Valves 1 8th January 2006 04:39 AM
coupling capacitor intermediate values adam12 Tubes / Valves 3 12th February 2005 09:44 PM
Copyright ©1999-2017 diyAudio
