My latest Project (nightmare) - diyAudio
Old 22nd April 2005, 04:04 AM   #1
Trout is offline Trout  United States
Trout's Avatar
Talking My latest Project (nightmare)
Welp,
I guess I have the bug. I started building another guitar amp.
Heres a few pictures of the progress from the past couple days.
Pair of 6V6's, 3-12ax7's & 5U4 rect.
Im taking a break from the wiring as its shown here in these pictures to build the Oak base it will set on. All of the Pots and jacks will be mounted on seperate front and rear plates routed into the oak base.
Top View
Power End
Middle
Last Shot
Notice the blue/wht wire? Am I Setting myself up for ground issues? or just being redundant?
I wasnt sure if it was better to count on the chassis as reliable ground or better to hard wire it to just a couple points. So Now Its BOTH!!
This is my 4th project this year, After not being in this hobby for nearly 30yrs, I think I Forgot more than I'll ever relearn LOL
Gene
Old 22nd April 2005, 07:06 AM   #2
frugal-phile(tm)
planet10's Avatar
Default Re: My latest Project (nightmare)
Another addict -- Good
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 22nd April 2005, 08:54 AM   #3
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
Default Oh dear...
That's going to hum like one of those words that we shouldn't post. The whole point of twisting heater wire is to minimise the size of the loops and to attempt to cancel the field, yet you've twisted your wire right up to the point where it became really important (near the small-signal valves) and then not bothered!
Yes, you really do need to keep a tight twist on the heater wire and take it from one valve base to the next. Big loops near valves are not allowed. Ideally, the heater wire should be pushed into the corners of the chassis and come up to the valves by the shortest route, which usually forces the valves to be in a line along one side of the chassis in low-hum designs. It's also useful to ensure that the sockets are mounted so that their heater pins are nearest to the edge of the chassis from which the heater wire will come.
Your wire looks to be rather thick (making it difficult to achieve a tight twist). Remember that by the time you reach the small-signal valves the heater current is reduced, so you can use thinner wire (which will take the required tight twist).
Sorry to sound so negative, but heater wiring is virtually impossible to replace afterwards, so you have to get it right first time.
Your positioning of valves isn't ideal, but it's far too late to change it now. The diagram of suggested heater wiring may help matters.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 22nd April 2005, 10:32 AM   #4
Frank Berry's Avatar
I'm concerned that your output transformer primary wires are running so close to the low level tubes. Oscillation (squeeeeel) is certainly possible.
Nice metalwork though!
Frank
Old 22nd April 2005, 11:38 AM   #5
I would have gone with a different colored table cloth myself.
Nice positioning of sockets and stuff.
Old 22nd April 2005, 01:33 PM   #6
Trout's Avatar
Default Re: Oh dear...
I hardly concider the comments negitive , That was actually one of the reasons for posting the pictures at this stage of construction. I was actually concerned enough about the heater current that I ran a seperate set of wires for the 6V6's and the 12AX7's.
Question, Would adding a full wave solid state rectifier to the heaters help the hum issue ? If so, how big of a cap would I need? Also, Would It be wise to apply DC to all filaments or just the 12AX's? or is it better to run it to everything on the 6.3v line
I have a couple sitting around that can easily handle the duty and it wouldnt be terribly hard to install.
Thanks for the Input!!!!!
And for Frank who posted:
OMG I Hope That doesnt happen, Recently(posted here) I built a beginner project as a warm up project that had a terrible squeeeeeeeeeeeeeel. Partly from ungrounded speaker ground, And partly from an unknown to me source.
I ended up replacing the 12AX with 12AU adding a ton of grid stoppers not present in original schematic , finally getting it under control. Mind you I had a 5u4 rect tube, A 12a?7 and a 6AQ5 + Trannies, Pots And Jacks squeezed into a 6.5x6.5x3 chassis!!
Thanks Guys,, I'll post more pics Soon!!
Gene
Old 22nd April 2005, 02:30 PM   #7
jlsem is offline jlsem  United States
jlsem's Avatar
One of the things I would be careful of are the non-inductive wirewound resistors. Although physically large, the ones pictured look like they are only good for 1/3 to 1/2 watt.
John
Old 22nd April 2005, 02:44 PM   #8
Using the Blue/White wire as a means of assuring a good ground connection is fine. I have seen many amplifiers use this method.
It assures a good ground without depending on the hardware to make a connection to the chassis.
Frank
Old 22nd April 2005, 03:27 PM   #9
SY's Avatar
DC never hurts, but do filter it or all you'll have done is move the noise up an octave. But you can probably get away with AC if you follow EC's diagram.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 23rd April 2005, 12:44 AM   #10
Trout's Avatar
OK,
I rewired the 12AX7's filaments as shown in This Picture
I have to admit, Its not perfect, But I am sure its a far cry better than the original job.
I would rather not add a SS rectifier, But, If It hums to much, Its an easy mod.
Right now Im Playing lumberjack hacking up the Oak for the wrap around base. I figure I should have it up and running by sat next week if all goes well.
If I could subtract all the Honey Dews It would be only 3 days from now HAHA
Gene
My latest project - DAC + headphone amp gmarsh Digital Line Level 105 13th December 2010 02:31 PM
my latest diy TT project berndt Analogue Source 2 7th August 2009 05:38 PM
Newbie's latest project gfinlayson Multi-Way 47 8th December 2006 06:38 PM
My latest subwoofer project sidd_raj2002 Subwoofers 14 4th December 2004 02:50 AM
Latest project for one and all Jocko Homo Everything Else 10 30th April 2002 05:02 PM
Copyright 1999-2017 diyAudio
