diyAudio Sponsor
Old 5th May 2005, 01:21 PM   #21
n0plb is offline n0plb  United States
Send a message via MSN to n0plb
Before I make another order for resistors would anyone like to make a suggestion on whether I would be better off dropping my plate voltage with a resistor or leaving the 280 to 296 volt plate voltage alone and ajusting the cathode resistors for required amp draw. I tryed replacing the cathode resistors to 390 ohm resistors and found that to get the amp draw into specifications I will need 520 ohm resistors. I tryed changing the plate resistance to a 270 ohm resistor with a 10 watt rating and it seemed to work until I accidentally touched it. Wow! hope not to do that again.
Any suggestions are appreciated.
Fixed Bias adjustment alexmoose Tubes / Valves 9 12th June 2009 02:32 PM
BOZ bias adjustment help rtate Pass Labs 16 11th July 2008 07:04 PM
Bias Adjustment Question dakotadave Tubes / Valves 0 9th July 2006 11:05 PM
Bias adjustment for Krell KSA 100 Alex helge Solid State 9 26th August 2003 01:41 PM
Page generated in 0.06366 seconds (64.21% PHP - 35.79% MySQL) with 11 queries
