Old 23rd April 2005, 10:53 PM   #21
hillly is offline hillly  Australia
What are the actual advantages of the CCS approach? It's seems an more elegant way of biasing but as you still can't bypass the cathode to ground it would appear that you still suffer the problems caused by local feedback.
Old 24th April 2005, 09:39 AM   #22
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Well yeah, that's kind of what you have to accept when you don't drive the other tube at all.
Tim
Seven Transistor Labs
Projects and Resources
Old 27th April 2005, 03:57 AM   #23
So one channel doesn't sound too bad. But I should use a better quality OPT. And something besides plexiglass for a chassis. (It was quick and easy). There is a fair amount of hum. I used a 3w 25ohm balance pot over the cathode resistor. I went to 6AV6 driver tube, moved the volume control to 100k at the input, removed the tone control. (still haven't gone to CCS yet)
But what I'm really wondering is, does this kind of circuit stand a chance of being an inexpensive way to get around crossover distortion? I like the "aliveness" of an my SE amp which is 6BQ5/6EU7. I'm thinking of trying EL34's in a similar configuration.
Comments? At the moment the 6W amp doesn't seem to have the quite the power of the SE amp. And sonic improvements would be easily possible with the SE amp by upgrading it's OPT's and PS also.
Jim
Anyone in the Eugene OR area want to get together to audition projects, do a swap meet or kick around ideas over a homebrew?
Wish I'd studied this stuff with as much interest 30 years ago!
Old 27th April 2005, 06:46 AM   #24
Sch3mat1c's Avatar
Huh? Crossover distortion isn't an issue until deep class AB. Very deep, if NFB is used.
Tim
sonic differences between inverting/non-inverting LM4780 VS both non-inverting LM4780 jarthel Chip Amps 5 19th July 2007 12:37 PM
whats the difference between inverting and no inverting mikee55 Parts 1 7th January 2007 10:36 PM
Aleph Phase Inverting / non inverting macka Pass Labs 9 22nd February 2006 07:01 PM
inverting / non-inverting op-amp circuits Learnincurve Solid State 11 21st January 2005 05:40 PM
Bridged/Stereo, w or w/o servo, inverting 3886, inverting buffer PCB Alexander Rice Chip Amps 9 27th March 2004 06:53 PM
Copyright ©1999-2013 diyAudio
