want to do PP-GM70 - Page 3 - diyAudio
Old 18th June 2005, 05:07 PM   #21
kevinkr's Avatar
I noticed a big mistake in the design of the output bias circuit. At the minimum you really, really need some high quality capacitors from the bias pot wipers to ground. Better still do what I suggest a couple of lines further along in this post. The transformer secondaries are floating off the 22K pots and the source impedance as well as ac signal level seen at the grids will differ depending on the position of the wiper. This is meant to be a dc adjustment only as well. I would recommend inserting a 50K resistor between the bias pot wiper and the secondary of the interstage transformer, in addition I would recommend installing about a > 0.33uF film cap from the cold end of each winding to the cathode return of the output tubes. This will provide a very well defined ac ground at the cold end of the driver transformer. Should sound a lot better too as the non-linearity of the wiper will not be an issue.. Your measured phase shift is related to the current configuration as well.
Kevin
Edited to improve clarity
Old 19th June 2005, 01:22 PM   #22
day is offline day  Thailand
thank youb Kevin
i will do it
Old 21st June 2005, 06:55 AM   #23
I have new bad thing . ITS get very hot just 50 ma bias same the circuit on the top.
the old once has no ITS work very good.
Old 5th July 2005, 03:11 PM   #24
the final
thay are work very good
Old 3rd January 2006, 02:20 PM   #25
this is my new PP-GM70 drive by vv302b with int ll1677
OPT LL1688.
Old 3rd January 2006, 02:22 PM   #26
this is copper plate
Old 3rd January 2006, 03:53 PM   #27
Giaime is offline Giaime  Italy
Giaime's Avatar
Send a message via MSN to Giaime
Whoa, some beautiful BIG work on those beautiful tubes...
yes, I like them BIG
the pictures with the lights off are AWESOME IMHO. I wish one day to build an amp like that...
Old 3rd January 2006, 04:34 PM   #28
Send a message via AIM to DigitalJunkie
Whoa! Look at those puppies glow!
Old 4th January 2006, 02:31 AM   #29
kevinkr's Avatar
Cool
Nice work, obviously a lot of thought and effort went into these.
Kevin
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 4th January 2006, 08:12 AM   #30
yes it very big and very hot but it very good sound.
GM70/GM70 parafeed SET? louischia Tubes / Valves 10 4th December 2008 03:12 PM
Another Gm70 amp !! HFGuy Tubes / Valves 4 8th July 2005 08:41 PM
GM70 Triode WALTER BURKHARD Swap Meet 12 21st January 2004 09:27 PM
Copyright 1999-2017 diyAudio
