want to do PP-GM70
want to do PP-GM70
Old 2nd June 2005, 08:15 PM   #11
SHiFTY is offline SHiFTY  New Zealand
SHiFTY's Avatar
Wow! Looks really good. Nice woodworking, is that a copper top plate?
Old 3rd June 2005, 05:38 AM   #12
day is offline day  Thailand
yas it is a 4 mil copper top plate.
Old 16th June 2005, 04:39 PM   #13
about phase splitter of interstage. I use scop put chanal a at gride of top GM70 and b at botom gm70. why phase splitter not stay on 180 at diferance freq.
1Khz it is 176'
Old 16th June 2005, 04:42 PM   #14
5khz
Old 16th June 2005, 04:46 PM   #15
10khz
Old 16th June 2005, 05:29 PM   #16
kevinkr's Avatar
want to do PP-GM70
A couple of thoughts, first are you sure that your scope probes are properly compensated? If they aren't they will exhibit slightly different phase shifts which might account for the error. Your scope may or may not have a probe calibrator, in any case a good quality 1kHz squarewave at a volt or so will do the job nicely. Secondly are you using chopped or alternate mode on your scope, alternate is what you would want to use at these frequencies on most scopes.
Finally if the load capacitances are significantly different across the windings you might see some phase shift. How big are your grid stopper resistors? Probe capacitance imbalances with large grid stopper resistances might cause additional phase shift as would significantly different miller capacitances and strays between the electrodes in those GM70's. I would measure the phase at the splitter transformer directly.
Check with a sine source that your scope probes and scope don't introduce different levels of phase shift before doing the measurement. I think this problem is most likely a probe/scope induced artifact.
Hope this helps..
Kevin
Old 17th June 2005, 02:51 AM   #17
Thank you Kevin. I will test it to night
Old 17th June 2005, 02:55 AM   #18
the circuit that i use
Old 17th June 2005, 06:41 PM   #19
protos is offline protos  Greece
protos's Avatar
How much power are you getting out of it?
And what are your impressions compared to other tube amps you have?
Old 18th June 2005, 02:22 PM   #20
i bias at 80watts.
i think it is very goog amp but i still tune it .
want to do PP-GM70Hide this!Advertise here!
GM70/GM70 parafeed SET? louischia Tubes / Valves 10 4th December 2008 04:12 PM
Another Gm70 amp !! HFGuy Tubes / Valves 4 8th July 2005 09:41 PM
GM70 Triode finwbu Swap Meet 12 21st January 2004 10:27 PM
