Different input valves for KT88 - diyAudio
Old 19th April 2005, 01:18 PM   #1
Question Different input valves for KT88
I'm thinking of building this amp but was wondering if I could use an octal instead of the ecc83 as I have achassis with PSU that I could use for it.What changes would I need to make to use 6sl7 or 6sn7?
Old 19th April 2005, 07:10 PM   #2
PRR is offline PRR  United States
PRR's Avatar
ECC83 is a Euro-name 12AX7 HI-Mu twin-triode.
Frankly, I think that plan has too much gain already. Maybe that is why it has the 68K grid resistor (500K would be quite safe).
So use 6SL7. Mu is a little down from 12AX7, maybe not enuff to notice. Look-up the base diagrams.
You might try changing the 1K cathode resistors a little higher or lower. My guess is that 1K4 is a good starting place for 6SL7, but I'm not inclined to analyze an SRPP today.
Experiment with a much higher KT88 grid resistor.
input/driver stage for kt88/6550 duderduderini Tubes / Valves 5 12th October 2010 03:21 PM
Valves Professor smith Pass Labs 47 10th June 2009 10:58 PM
Which valves for MF CD-T paultb10 Tubes / Valves 1 7th October 2007 04:42 PM
Input level required- PP KT88 Sherman Tubes / Valves 6 21st August 2006 04:47 PM
WW2 valves exurbia Swap Meet 0 20th September 2003 09:19 AM
Copyright 1999-2017 diyAudio
