I have plans to build an active 2 way speaker design using a Jordan JX92s (already have them) and mating with another 10 incher, and tubes are high on my list.
It seems whatever 6922 tube active x-over circuit design available at the moment (that I know of) runs with high voltage (above 100v). I'm not sure bout Marchand though. Is it possible to run the 6922 at lower voltage (below 50v) which then allows large capacitance PSU to be used ? Anyone with such a circuit ? regards, Will. |
#2 | |
I don't know what kind of active circuit you intend on using, but chances are it needs to be at least partially direct coupled for stability, and that demands voltage. Even tubes in general do not like <50V. Tim |
#3 |
Based on the fact that 6922s are widely used as buffer circuits, running them with low voltages (below +/- 50v) allows a large PSU capacitance to reduce noise/hum without having to resort to chokes.
The active x-over circuit I'm referring to is a 4th order L/Riley. regards, Will. |
#4 | |
Tim |
#5 | |
#6 |
frugal-phile(tm)
You can run 6922s on that low a voltage (Joe R uses +/- 35 V on his buffer in the TBIGC), but they work better with higher voltages.
Remember that the power supply is critical to the sonics of the amp and caps are probably the most colorful of all passive components -- no electrolytics is a good goal, and those get really big & really expensive if you want to use lots of C. dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#7 | |
That's exactly my point Dave... I agree running with higher voltages will sound better, and it's easy to get away with +/- 40 volts, which requires 50v rated cap to do the job. Come on, do you really think I'm going to use one single large cap for the job ? Simple solution - just parallel multiple 1000uF caps (probably 20 of them) regards, Will |
#8 | |
Previously: Kuei Yang Wang
Location: Somewhere nice on planet earth where censorship of Ideas is frowned upon
Konnichiwa,
The cost for making the PSU something like +/-160V and thus the more linear is quite notional. Instead of 20 pcs 1,000u/50V, buy a simple pair of 115+115V: 9V+9V mains transformer, operate one "reverse" and use a pack of 6pcs 100uF/250V capacitors with a set of 1K resistors (final values of R & C would depend on exact current drawn) and you get a well filtered +/-160V for no more money than your "big cap" supply and things will sound better too. Sayonara |
#9 | |
frugal-phile(tm)
Me i'd grab a pair of the 115-->115 V 170mA isolation transformers that are surplus from old-style razor plugs.... quite a few in my stash dave
#10 |
Okay, lets not go off topic shall we ?
Anybody with a 2 way L/R 4th order active cross over circuit using 6922 running off at +/- 40volts ? |
| Generating and running FIR filters for active loudspeakers | Dan_E10 | Digital Line Level | 5 | 10th September 2008 12:26 AM |
| What advantages running ported midbass if you are running a sub? | mitchyz250f | Multi-Way | 3 | 20th May 2008 02:34 PM |
| Running A Component Set Active Off of A Single Amp... | HsOffRoad | Car Audio | 5 | 5th March 2008 02:29 AM |
| How low 6922/ECC88 can go? | lumanauw | Tubes / Valves | 31 | 2nd April 2004 01:01 AM |
| 6922 | marjan | Tubes / Valves | 56 | 9th November 2003 07:13 PM |
