different measurements
Old 17th April 2005, 04:18 PM   #1
resident is offline resident
Account Disabled
Question different measurements
I have build this input stage for my 6L6GC amp (without the antiringing network).
But with different B+ at the phase splitter.
My measurements (hand writing letters) are a little bit different than the schem's.
Do I have problem with these measurements?
Old 17th April 2005, 04:40 PM   #2
On Hiatus
SY's Avatar
C1 may be leaky or you might have a slightly sour 6CG7.
edit: DUH! Or your meter is loading that grid down a bit. That's most likely. Your voltages are fine.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 17th April 2005, 08:25 PM   #3
Account Disabled
I use 6SN7.Sorry that I didn't mention.It's the same,though.
And it's a new EHX.I have done measurements with other 6SN7s with the same results.
C1 is a new Audyn MKP cap.So,....
Very interesting! Why not the other grid,too?
Old 17th April 2005, 08:51 PM   #4
On Hiatus
SY's Avatar
The impedance. The lower grid in the diagram is fed through a 1M resistor. The meter's impedance provides a voltage divider to ground. For the upper grid, the meter forms a voltage divider with only 47K ohms (or so), so it doesn't much perturb that voltage reading. Your meter would appear to have about a 10M impedance.
BTW, to confirm that I was an idiot, connect the meter from grid to grid (i.e., across the 1M resistor)- I bet it reads close to zero volts.
Old 17th April 2005, 09:04 PM   #5
Account Disabled
SY,
thanks for your help!!
I'll measure it tomorrow.
different measurementsHide this!Advertise here!
XAB Measurements DarkOne Pass Labs 12 16th April 2006 10:59 PM
New T-Amp measurements Pano Class D 12 14th March 2006 11:32 AM
SW measurements Grandma´s_SUB Everything Else 9 10th January 2005 01:34 PM
anyone have measurements of TB 871? morbo Multi-Way 5 27th November 2004 03:10 AM
Some CCS measurements Jocko Homo Solid State 10 29th May 2002 12:54 PM
