diyAudio Sponsor
Old 17th April 2005, 12:01 PM   #1
pingfloid's Avatar
Arrow Elektor ECL86 RIAA Preamp
I am planning to build this RIAA preamp with ECL86 from the Elektor magazine, but without the input transformer. What is your opinion about the circuit? Have some of you already tried it?
Manuel
Old 17th April 2005, 12:52 PM   #2
analog_sa's Avatar
Lots of similar and better circuits all over the net . I would rather avoid this one as the designer was clearly not into serious hifi - just have a look at the silly coulpling cap values - and elcos!
And, ha, ha, a coupling cap after the transformer. What a moron!
Old 17th April 2005, 01:58 PM   #3
pingfloid's Avatar
Mmmm Yes, the input cap is weird.
I've already bought all the components. ¿any suggestion about how to re-use them?
Old 18th April 2005, 01:05 AM   #4
gmilitano's Avatar
Default ECL86 RIAA Preamp
Can you share some links to these ECL86 RIAA preamps.
Gio.
Old 18th April 2005, 05:25 PM   #5
pingfloid's Avatar
¿What is your opinion about this ones? They all use ECC83
Dynaco:
http://www.bonavolta.ch/hobby/en/audio/dyn_upas.htm
http://www.bonavolta.ch/hobby/en/audio/dyn_pas2.htm
RCA:
http://www.bonavolta.ch/hobby/en/audio/rca.htm
Ohashi (1-1/2 ECC83):
http://www.bonavolta.ch/hobby/en/audio/ohashi.htm
Zur Linde SRPP output (1-1/2 ECC83):
http://www.bonavolta.ch/hobby/en/audio/lindesrp.htm
(some values of the components maybe hard to find)
Cheers
Manuel
Old 18th April 2005, 05:28 PM   #6
analog_sa's Avatar
No, i have never noticed ECL86 preamps and see little reason one should force this tube for phono.
Old 18th April 2005, 05:38 PM   #7
analog_sa's Avatar
ECC83 is probably not the best sounding tube but is widely available and easy to use. I still have warm memories of Marantz 7C phono section and the link to 'Ohashi' or AR SP-3 presents a very similar circuit. Thanks to the CF and NFB output impedance is low and one can feed a pot/power amp directly.
EAR834 seems like another very good choice
Old 18th April 2005, 06:22 PM   #8
gmilitano's Avatar
RCA:
I have the iron and tubes for the RCA preamp and plan to try it out eventually. I think there is an error in the schematic in your link. Compare the capacitors marked * in your link with the link I have posted below.
See
http://www.diyaudio.com/forums/showt...366#post526366
for a scan of the schematic from the RCA book which shows a different value for the np capacitors.
Good luck and let us know how you make out.
Old 19th April 2005, 02:36 AM   #9
frugal-phile(tm)
planet10's Avatar
Originally posted by GG
the RCA preamp
The as built map for Chris' version....
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 19th April 2005, 02:37 AM   #10
frugal-phile(tm)
planet10's Avatar
and the power supply (severe overkill on this)
MAT02, 03 Elektor preamp schematic Samuel Jayaraj Elektor 85 30th November 2011 10:33 AM
ECL86 preamp critique please aardvarkash10 Tubes / Valves 15 22nd April 2008 11:55 PM
ECL86 preamp? Hanzwillem Tubes / Valves 23 16th June 2007 11:45 PM
RIAA Pacific deluxe from Elektor peranders Analogue Source 4 26th February 2004 03:52 PM
Elektor Battery Preamp Kit for sale Jason Hubbard Swap Meet 0 18th June 2001 12:58 PM
Page generated in 0.12041 seconds (82.85% PHP - 17.15% MySQL) with 11 queries
