diyAudio Sponsor
Old 14th April 2005, 01:51 PM   #1
Default bias meter and pot lead length
based on diagram, (existing arrangment is inside chassis (chassis can not be altered)and i would like to make them external for ease of adjustment for tube rolling)
what length of lead can I use to make these (pot and meter) external i.e 200mm (based on noise pick-up etc)
Old 14th April 2005, 05:14 PM   #2
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Doesn't matter unless the impedance of the driver is very high (211 amp eh? Yeah, you're safe...no one EVER uses pentodes anywhere...).
If in doubt, slap on a nice electrolytic from wiper to ground.
Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing.
The key to being a successful Audiophile: "I reject your reality and substitute my own!"
Old 15th April 2005, 11:47 PM   #3
Enzo is offline Enzo  United States
That is a 1 ohm resistor. ANy noise trying to get in will have to overcome that low 1 ohm impedance. In short, nothing is going to get in that way. It will not be a critical bit of wiring.
how to make this esr meter work with 250uA Panel meter dytln_02 Everything Else 2 27th January 2007 10:13 PM
Mounting power supply caps-lead length pjpoes Parts 0 12th December 2006 05:23 PM
Calrad meter for monitoring bias aleph2 Mattyo5 Pass Labs 16 7th January 2005 10:58 AM
bias meter el capitan83 Tubes / Valves 4 20th December 2004 06:03 AM
Adding a bias meter to Zenlite Michael Rothacher Pass Labs 11 4th February 2003 09:13 PM
Page generated in 0.07602 seconds (70.60% PHP - 29.40% MySQL) with 11 queries
